boost a pump
Old Jan 23, 2009 | 12:42 PM
Blow Torch's Avatar
Blow Torch
Default boost a pump
What determines whether or not you use the 20amp or 40amp boost a pump?
Has anyone used the MSD boost a pump?
Old Jan 23, 2009 | 01:40 PM
lucky131969's Avatar
lucky131969
It's my understanding that whether you choose a 20 or 40 amp depends on if you are using a high performance pump(draws more current) and if you are FI or N/A.
Old Jan 23, 2009 | 02:06 PM
Blow Torch's Avatar
Blow Torch
So since I'm using the LPE pump I guess I would use the 40amp.
I can't get much info in the MSD BAPs. Not sure if they're just new, or no ones got any real data on them.
To boost a pump
