line loc or not?
Old Jan 23, 2009 | 01:57 PM
bumble-z's Avatar
bumble-z
Default line loc or not?
Curious to know on a M 12 6 sp., ( if a line loc is better on your braking system then not) when doing burnouts @ the strip? Thanks in advance. Where would be a good place to install the (activator button ?) , on shifter, ashtray, etc, etc. Could you accidently activate these units while going down the road? Sorry for so many questions.
Old Jan 23, 2009 | 02:28 PM
87SAM's Avatar
87SAM
You don't need one with a manual trans.
Old Jan 23, 2009 | 03:22 PM
Drewstein's Avatar
Drewstein
WTF it's easier and better with one on a manual trans.
Old Jan 23, 2009 | 03:23 PM
nickolbag's Avatar
nickolbag
Get it. A lot easier on yourself and the car.
Old Jan 23, 2009 | 10:40 PM
SuperSpeed's Avatar
SuperSpeed
St. Jude Donor '08-'10
yea dude someone lied to you! a line lock is 100 times better on your car not to mention easier for you. Using your brakes to hold you still during a burnout is horriable for your brakes and for your rear diff. I would spend the 200ish on a line lock if you plan on doing a good amount of burnouts.
Old Jan 24, 2009 | 07:47 AM
vsocks1's Avatar
vsocks1
Much easier on the rear brakes...the fronts are still holding the car. Rear diff is then free to spin with no rear brake loading.
Old Jan 24, 2009 | 09:16 AM
paint it black vette's Avatar
get a life . get a linelock
Old Jan 24, 2009 | 11:01 AM
ericdwong's Avatar
ericdwong
Yup I agree. I accidentally did a clutch burnout once Never again with the line lock!
Old Jan 25, 2009 | 10:44 AM
Rob Petyo's Avatar
Rob Petyo
Old Jan 25, 2009 | 08:32 PM
evo2ls1's Avatar
evo2ls1
get it saves the clutch packs a little stress and it makes it a lot easier! i went with the cartek unit 2hr for me to install hooked it up backwards to the dist. brake block.
To line loc or not?
