I'm another person that has been using the DIY car wash high pressure wand to clean my engine.
I have been doing this on every car I have ever owned and NEVER had any problems.... period.
the electrical connectors under the hood are weather pack connectors, and are made to not let water into them.
when I first got my car I used foamy engine cleaner to clean the grease off the engine.
Now I just use high pressure soap, followed by high pressure rinse.
I dry it with a leaf blower and spray the motor with no touch, then wipe it down with a small rag.
the motor looks brand new after!
do what you feel is right for you, there are obviously lot of different opinions here about the way it should be done.
I power wash all my engines and always have! The only problem I have ever had is the Knock sensors under the manifold.They are like Hemi spark plug holes. The boot leaks, water gets in hole and corrosion kills the sensor , usually the rear one( there are 2).I always silicone the boots after installation and pressure wash away.I also run my ZO6 through the auto carwash.I aint washin no car !!!
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Originally Posted by Sinister-one
Not to knock Lucky's theory...
I wash my engine compartment every 2 weeks at the local car wash with pressure using soap and water rinse. NEVER had any problems and the compartment looks BEAUTIFUL !
WOW !! Rags, Q-tips, aerosol brake cleaner, diluted SIMPLE GREEN and diluted WINDEX !
If I had that much time on my hands I wouldn't know what to do with myself !
As mentioned before, I just wash mine at the car wash. And let me SIMPLIFY this... I don't pull the trigger and use the PRESSURE from the gun. When it starts it has a very light spray coming out of the gun and that's what i use. I pre-soak with soap or engine cleaner and the when done I flip the switch over to spot-free-rinse and rinse off all the soap or cleaners. and then I wipe it all down with a couple of old shammies.
I always go the pressure wash stations. I pre-soak with engine cleaner and rinse with pressure hose at a distance, i never get right in there with it. Or, if they have the spot-free rinse, i use that. The spot-free rinse is usually a low pressure rinse. Never had a problem, i've done this with every car i've owned.
Well you guys I did not mean to start a big fight. Thanks for the input.
Over the years, this forum has answered so many question for me, and I am thankful for that. I just thought someone before me has experienced this situation, and I could learn from their experience.
Again thank you for your input.
I think the reason you have corrosion is because with that low miles I bet the previous owner made many short trip that never allowed the engine to fully warm and evaporate any condensation.
I recommend filling a bucket with diluted simple green and using rags and brushes gently cleaning it then going back over it with a moistened rag and the protectant of your choice - do the aluminum parts too.
While others do, I would not pressure wash.
If you do it in 2 or 3 sessions it makes it manageable and fun rather than a chore. Then all you need to do to maintain it is a wipe down every other time you wash or every time if you prefer.
I would stress very diluted SIMPLE GREEN if that's your choice where anything aluminum is going to be cleaned.
If you go to their website, it warns about the potential for discoloration of any aluminum (raw or polished can be affected), with the use of SIMPLE GREEN.
Billet aluminum may not be affected as much as cast aluminum.
I used it in diluted form on a raw sbc aluminum intake manifold and it turned it black. It cannot be reduced or removed because of the porous nature of the cast aluminum.
I know of others who used it on polished aluminum with similar results.
So, if you chose to use it, find an inconspicuous spot and test the dilution you're using.
..... and all other unfinished engine components have become corroded.
If you see corrosion, good bet the ground terminals are too. There are several threads with great pictures showing where they are. I would definilty clean them.
i've washed mine before, with little-to-no pressure from my hose, but I have a question, well 2. One, my intake manifold (stock Ls6) is course, what do you use to dry that, if I use regular towels it leaves fuzz on it. The second question is should I take some of that blue-colored shop-tape stuff and cover the fins on my alternator so water doesnt' get in? I cover my battery up and avoid shooting the water over there at all bc of the computer.
ZEP-A-LUME
TYPE : Aluminum Cleaner and Brightener PROD.# 1063
BENEFITS : Zep-A-Lume is a premium aluminum cleaner and brightener. It is designed for use on aluminum trailers where its fast cleaning and super brightening powers are required to maintain attractive appearance. It is composed of a blend of powerful cleaners and emulsifiers to cut through road film. It also contains the most powerful agents known to provide outstanding brightening action. Removes both dull oxide and unsightly diesel smoke from trailers. Brightens most trailers without prior washing or brushing. Will not "brown" or "snow" trailers. The product`s concentration assures economy in use
I just cleaned mine last Saturday, first time since last Spring for my DD. It wasn't bad, just a little dusty. First I brushed off the worst of the dust, the got the air compressor and blew off the rest and got all the nooks and crannys. Then I used some of this to make it shine... http://www.griotsgarage.com/product/...g,+8+ounces.do
Works nice!
I washed my motor about 2 times with the regular hose with no problems. On the 3rd time i had some trouble. I started it and went for a ride and it went to reduced power mode.I couldnt go over like 40 mph. Turned out a couple of my sensors got wet had to go one by one to find the wet ones. Once i found them and dried them problem went away. Cant remember which ones were the problem. Now all i do is wipe it down that little problem was a pain for me.
Got 3 vettes, a dodge pick-up, an 08 Mustang, and the wife drives a minivan, I have always pressure washed the engines. They all look like brand new, and if something ever begins to leak I can spot it right away. I'm a mechanic, that works on forklifts, heavy equipment, and other internal combustion things, and I squit them all. Just use your head and don't spray stuff that shouldn't be sprayed. When I'm servicing forklifts, or other equip. I don't want to get all greasy.
