One wheel spin???
Old Jan 25, 2009 | 08:37 PM
evo2ls1's Avatar
evo2ls1
Default One wheel spin???
i went to the track a lil while back, second pass, doing my burnout currently DTE stage 2 diff using a line lock car i think was in traction off but may have been in comp mode but started my burnout both tires spun then halfway through only one tire actually spinning is there any time this is normal or is something broke??? oh and clutch bit the dust on the attempted third pass, i am going with a spec 3+ do i need any trans upgrades while its out of the car? thanks...
Old Jan 25, 2009 | 10:29 PM
vsocks1's Avatar
vsocks1
Is there somethong wrong with the trans?
Old Jan 26, 2009 | 12:00 AM
ALLEGRO's Avatar
ALLEGRO
Sounds like the limited-slip chunk is gone. Good Luck
Old Jan 26, 2009 | 12:37 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The springs that hold the tension on the clutches in the rear are notorious for breaking. The DTE stage 2 includes only OE clutches. You need to get a HD clutch pack from someone and have it installed. Maybe it will subside when as the rear cools. You will need to do another burn out to see if there is permanent damage. As for tranny upgrades, if you're dragging the car, you should get a DTE brace and I would upgrade all of the internals to triple carbon blockers, billet keys, bronze fork pads etc. Your rear end had better have a 3-rib case too.
Old Jan 26, 2009 | 12:57 AM
evo2ls1's Avatar
evo2ls1
i hope its not permanent, because i really dont want to have to buy another new diff. who do you guys recommend for the tranny upgrades, i was planning on doing the internals of the trans and the clutch next month and a cam looks like i will be spending that on a new rear chunk
Old Jan 26, 2009 | 01:00 AM
BLOWNBLUEZ06
Many happy customers from RPM transmission and gear.
Old Jan 26, 2009 | 10:42 AM
lucky131969's Avatar
lucky131969
To One wheel spin???
