Remote Clutch Bleeding
Old Jan 27, 2009 | 06:17 AM
Atok's Avatar
Atok
Default Remote Clutch Bleeding
I've been looking to install a remote clutch bleeder on my Z06. So far I've found three companies that sell a kit, RPM, LAPD, Tick Peformance.
I know it's going to be a PITA to install without removing the bell housing but does anyone know if one of these kits is easier than the others?
Old Jan 27, 2009 | 06:37 AM
vettenuts's Avatar
vettenuts
The RPM looks to be the easiest (if you can say one is actually easier) but I am not sure anyone has actually done this. A lot have discussed it.
Old Jan 27, 2009 | 08:52 AM
LDB C5's Avatar
LDB C5
I would bite the bullet and drop the TT. If (when?) you run into trouble, you are going to have to drop it anyway. Simple Corvette work instructions: If you don't have time to do it right; Where are you going to find the time to do it again?
Old Jan 27, 2009 | 11:03 AM
DRR's Avatar
DRR
I installed the LAPD bleeder when I pulled the trans, diff and t/tube and I use a mity-vac to bleed the system.
Old Jan 27, 2009 | 07:04 PM
trudsmtuner's Avatar
trudsmtuner
Navigator
I have a Ticks performance bleeder, one of the first made.
I installed while tube was out. but i would say would be easy while still in the piece you screw into slave cylinder that you wrench on is about 1 inch long so be easier to grab with wrench while your just trying to feel around.
I went with tick perfromance adjustable master cylinder with new lines z06 slave and remote bleeder. spec 3+ clutch and billet steel flywheel.
shift like a dream with stock shifter.
Old Jan 28, 2009 | 04:38 PM
Corvette Don's Avatar
Corvette Don
LAPD's bleeder has a speed bleeder on it which is a HUGE help
Old Jan 28, 2009 | 05:45 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
I just installed a remote bleeder (tick) while replacing my clutch and slave cylinder. I don't see how you could do this without removing the drive train. I'm sure that with the drive train on the floor, all three should be fairly easy to install.
To Remote Clutch Bleeding
