Oil filter removal question
Old Jan 22, 2002 | 11:27 AM
TeamZ06's Avatar
TeamZ06
Default Oil filter removal question
Is it safe to remove the oil filter without draining the oil pan?
I know that seems like a really stupid question, but I'd feel even more stupid if several quarts of oil poured out onto the ground; better safe than sorry.
TIA,
TeamZ06
Old Jan 22, 2002 | 11:40 AM
h2opolo's Avatar
h2opolo
Default Re: Oil filter removal question (TeamZ06)
I always drain the oil first then the filter comes off, unless you have a real big wide pan and don't mind the rush of oil go for it.
I just did my first oil change this weekend, was a piece a cake and saved my self a lot of money.
[Modified by h2opolo, 10:41 AM 1/22/2002]
Old Jan 22, 2002 | 12:14 PM
carpe dm's Avatar
carpe dm
Yes, you can do it. Some folks change their filter at 3K and their oil (and filter) at 6K., etc. :)
Old Jan 22, 2002 | 02:14 PM
SwissVette_Joe's Avatar
SwissVette_Joe
TIA,
TeamZ06
Z06, you are completely RIGHT! There are never stupid questions, but only stupid drivel answers! (=> straight translation from german Language, I hope it works similar in english.....:), if not you might give me some training )
....and, is this C-Forum not exactly set-up for just such purposes? Asking, asking, asking, learning more and more? YOU all know the answer!!
Thanks, Joe.
Old Jan 22, 2002 | 03:56 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
punch a hole in the bottom of the filter with a nail,then loosen the filter a little bit and when the oil stops remove the filter. only the filter will empty unless you have a external oil cooler.
Old Jan 22, 2002 | 04:52 PM
MySea6's Avatar
MySea6
Default Re: Oil filter removal question (clem zahrobsky)
I always use this method and remove the filter first. It will stop dripping in no
time and I believe it allows the oil pan to drain faster and more thoroughly.
Old Jan 22, 2002 | 07:37 PM
99 Corvette's Avatar
99 Corvette
Thanks for telling us about that. I'm going to be changing mine in a few days and this will help me a lot since I usually just take it off and get oil all over the place when it runs down the sides and I drop it :smash:
Jerry
To Oil filter removal question
