traction
Old Jan 28, 2009 | 08:05 PM
carney1's Avatar
carney1
Default traction
Not sure what catagory I shoud ask this.
I have put .3mm shorter tire on the rear of my 2004. When I get above 55 mph the traction assist come on and shuts it down. My speedo is off by approx 2 mph also (I anticipiated this).
I can manually shut off the traction assist, but I must do it everytime the car is started. Can anything be done to correct this in the computer or sumption permanently.
Old Jan 28, 2009 | 09:30 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
You say ".3mm shorter tire on the rear"
Shorter than what? The stock rears or shorter than the fronts?
Most people agree that the rears need to be @ 1/2" greater in diameter than the fronts to avoid problems with traction control.
Old Jan 29, 2009 | 03:49 PM
carney1's Avatar
carney1
I put on Vredenstien 275/35/18 on the rear, that is the only size they have that come close to the stock size. I really like the tires by the way.
Old Jan 29, 2009 | 04:53 PM
carney1's Avatar
carney1
fronts are the stock size 245/45/17
Old Jan 29, 2009 | 06:14 PM
Bill Dearborn's Avatar
Bill Dearborn
Only way to solve it is to get new rear tires. There is no way to reprogram the EBCM which is the module that controls the Traction Control. Welcome to the 21st century.
Bill
Old Jan 29, 2009 | 07:56 PM
carney1's Avatar
carney1
problem is that vredenstien does not make the exact size for the rear..I find that strange, however guess I will live with turning the TC off at startup, like I stated before, I really like the tires (if they hold up and wear well). I only have approx 5,000 miles on them... thanks for the info
To traction
