P1571 Code Driving me Crazy!
Old Jan 28, 2009 | 09:43 PM
xboxexpert's Avatar
xboxexpert
Default P1571 Code Driving me Crazy!
I've had this P1571 code ever since I bought the car. It always says H for History after it and I clear it but it comes back....any ideas?
Old Jan 29, 2009 | 12:26 AM
Bill Dearborn's Avatar
Bill Dearborn
You don't have to worry. Here is the info from the GM Service Manual.
Bill
History DTC P1571 Stored and Will Not Clear #PI00219 - (Jul 2, 2002)
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Vehicle may have a DTC P1571 [ASR (Automatic Slip Regulation) Desired Torque Circuit] stored in history that cannot be cleared. DTC C1277 (Requested Torque Signal CKT Malfunction) is NOT present and there is No Service Vehicle Soon lamp or powertrain related lamps on.
Recommendation/Instructions:
This is a normal condition. All 1997 YBs will have a DTC P1571 stored as history in the PCM that cannot be cleared. If P1571 is current, follow the trouble table in SI Document Number 101551. It should be noted that the schematic in this document incorrectly lists a ckt 449 dk blu/wht and calls it Real Time Dampening. This ckt is not present and should be ignored for both 97 and 98 (Document Number 203769) model year SI. A Service Information Update has been submitted.
Old Jan 29, 2009 | 12:31 AM
xboxexpert's Avatar
xboxexpert
Thank you very much. Go check out my TPS tutorial when you get a chance.
http://forums.corvetteforum.com/c5-t...-tutorial.html
Old Jan 30, 2009 | 02:21 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I have it also. Not much we can do about it from what I hear.
To P1571 Code Driving me Crazy!
