Control arm issue
Old Jan 29, 2009 | 05:29 PM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Default Control arm issue
Hey all, I'm trying to drop my front lower control arms to get to the leaf spring but it's fighting me. I've removed the lower shock mount and removed the nut that holds the control in place but the bolt/control arm won't drop away. I don't want to hammer the bolt out - I'd hate to strip the bolt.
Thoughts?
Old Jan 30, 2009 | 02:12 AM
Last C5's Avatar
Last C5
Thoughts?
The control arm isn't going to just drop away, your going to have to persuade it. Loosen the ball joint nut up to the top of the threads and then either use a plastic dead blow hammer on the end of the A arm (with a piece of wood to protect it) or use a ball joint separator (not a pickle fork) to pop it loose. Some people undo the nut until it's flush with the top of the ball joint post and give the nut a sharp rap with a hammer. If you do this cover the nut with a piece of aluminum bar or something to give it a little protection at least.
Old Jan 30, 2009 | 04:00 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Ok this my seem a little unconventional but it has worked every time when I needed the leafs out in the front or to get to the adjustment bolt.
Put a jack under the front rotor and start jacking it up. It will put a ton of pressure on the lower joint and it will pop and no I have never damaged the rotor.
Now I just remove the 4 bolts on the upper control arm and steering tie rod end. It is just easier IMO>
Old Jan 30, 2009 | 11:02 AM
Last C5's Avatar
Last C5
That is a new one. I'm getting ready to change hubs on a couple of cars, I'll give it a try. Thanks.
Old Jan 30, 2009 | 02:38 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I think you missed the step on removing the LCA from the spindle or the UCA from the frame
am I correct?
Old Jan 30, 2009 | 03:09 PM
slothy's Avatar
slothy
i just removed the uca from frame when i didnt mine.
Old Jan 30, 2009 | 04:21 PM
FUN LS1's Avatar
FUN LS1
here is the prob i am having right now - the lower control arm is down but its like its not down far enoungh.
Old Jan 30, 2009 | 04:33 PM
FUN LS1's Avatar
FUN LS1
nvm got it
Old Jan 30, 2009 | 05:58 PM
SteveDoten's Avatar
SteveDoten
nvm got it
you needed to removed the UCA from frame or LCA from spindle?
Old Jan 30, 2009 | 06:26 PM
FUN LS1's Avatar
FUN LS1
Nope, needed to disconnect the sway bar link.
To Control arm issue
