400 plus hp c5
Old Jan 30, 2009 | 08:19 PM
vet777's Avatar
vet777
Default 400 plus hp c5
need a proven recipe to make 400 hp to the wheels, without going to radical,without a stall, i have 01 c5 auto ,tpis long tubes, corsa catback, mti cold air, mti computer upgrade ,01 ls6 cam,springs, dyno 340 hp to wheels,12.5 in the quarter, pitifull 60 ft time in the 2,s , just purchase stock ls2 243 heads, I don"t want to spend much money on port work,whats a good cam thats streetable? thanks jim.
Old Jan 30, 2009 | 08:47 PM
7thson's Avatar
7thson
Find a good tuner to recomend a tried and true cam instead of guessing. Mill your 243's to achieve 11 to 1 compression and add an underdrive pulley. Make sure your cam selection allows enough piston to valve clearance. Also beef up all of your valve train parts such as hardened pusrods and a quality set of valve springs to match your cam. Good luck. I have been researching and collecting parts for a couple of years and have the same goals as you by the way. Kevin.
Old Jan 30, 2009 | 08:52 PM
mobman's Avatar
mobman
Old Jan 30, 2009 | 08:53 PM
vet777's Avatar
vet777
thanks
Old Jan 30, 2009 | 09:34 PM
Wickd1's Avatar
Wickd1
Look at my sig, and theres your formula with a auto.
Old Jan 30, 2009 | 09:49 PM
Jettech's Avatar
Jettech
With a bigger cam you will probably benefit greatly from a higher stall converter. I changed my cam first and then installed a Vig 2800. It was definitely one of the best mods I've done to date. It is quite a bit quicker, and much more fun to drive.
Old Jan 30, 2009 | 09:53 PM
kingsey's Avatar
kingsey
224r cam from texas speed
Old Jan 31, 2009 | 03:52 AM
kendo347's Avatar
kendo347
I got 409rwhp and 405 rwtq with a 224/228 581/588 112 cam, 5.3 ported heads and all the usual bolt ons.
Old Jan 31, 2009 | 10:03 AM
99 vett babycar's Avatar
99 vett babycar
see my sig for a shopping list of mods
Old Jan 31, 2009 | 10:33 AM
dankhts's Avatar
dankhts
Is that the comp 54-444-11 cam? I've had a few guys tell me they got over 50hp gain with that cam and a good tune....
Old Jan 31, 2009 | 11:56 AM
kendo347's Avatar
kendo347
No. It is a custom grind comp cam on a 112 lsa with +4 degrees of advance timing. Real close to the mamo cam which has 114 lsa.
Old Jan 31, 2009 | 12:26 PM
7thson's Avatar
7thson
Not to be a hijacker here but this is the cam I ended up going with along with ls6 intake, ud pulley and ls2 heads with Patriot Gold springs and Yella terra rockers. I will post my results when I get it tuned in a few months. I work slow.
Old Jan 31, 2009 | 01:19 PM
Corvette Don's Avatar
Corvette Don
Mill heads to 59 or 60cc, 224R cam from texas-speed, UD Pulley and a GOOD tune and you will be at 400+ rwhp.
Old Feb 1, 2009 | 01:03 PM
edcmat-l1's Avatar
edcmat-l1
The better the heads are, the more power you'll make with less camshaft. Best bang for the buck on those heads is a 5 angle competition valve job. You may still have trouble hitting 400 rwhp without a good CNC port job though. Cam specs will be key too.
Old Feb 1, 2009 | 11:26 PM
paint it black vette's Avatar
ran that cam224/230 on 114+2 lsa, with tsp 2.5 ls-6 heads, kooks lt 1 3/4, 3200 stall and 3.42 gears on bfg 295x35x18 drs with stocktires on front, car made 423rw and ran11.524 best at a weight of 3450lbs, eventually added drag pack 90/90 3.73 and 3600stall and ran 10.974 with 437rw at a weight of 3330lbs
Old Feb 2, 2009 | 07:05 AM
7thson's Avatar
7thson
I see you ran that came as in past tense. What did you think of it from a drivabilty stadpoint? Why did you get rid of it?
Old Feb 2, 2009 | 11:43 AM
Sinister-one's Avatar
Sinister-one
I'm hoping to hit the 400 plus HP mark with my bolt on mods...
Vararam CAI
LS6 intake
SuperMaxx headers, x-pipe, hi-flow cats
Z06 Ti Catback
G5X3 cam 114 w/dual springs
Ported polished TB
To 400 plus hp c5
Old Feb 3, 2009 | 09:09 AM
Corvette Don
Vararam CAI
LS6 intake
Z06 Ti Catback
Ported polished TB
Add a UD Pulley too and you should have no problem hitting 400
Old Feb 3, 2009 | 09:41 AM
Sinister-one
What is all hoopla about the UD pulley ??
Old Feb 3, 2009 | 03:33 PM
RAWPOWR's Avatar
RAWPOWR
2000 C5 M6
Stinger Cam(224/230 113+2)
PRC Stage 1 LS6 Heads
Vararam
Ported LS6 Intake and TB
160 Stat
Kooks 1 3/4 Headers
26 lb. injectors
Mr Z Tuning
440 RWHP and 405TQ
I had all of the work done at RaginRacin in Scott, LA. You can give them a call and see what kind of quote they can set you up with. Check out their webbsite www.raginracin.com they are a Supporting Vendore on the forum
