Lost round one
Old Feb 2, 2009 | 10:13 AM
slothy's Avatar
slothy
around 230-240lbs
http://texas-speed.com/shop/item.asp?itemid=89&catid=36
Old Feb 2, 2009 | 10:58 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Hold up a min.. You pinned the crank, correct? I believe you are already done. The primary reason the Tq values are so high with the stock setup is due to the fact the pulley drives the accessories from the non-keyed crank and those accessories are constantly pulling on the pulley in a direction that would loosen the bolt.
You've alleviated that stress by pinning the crank - there is no more rotational load on the bolt - now all the bolt is doing is keeping the pulley seated against the oil pump.
If you met the push-on (end of crank snout to pulley bore / lip) requirements, I would call it good, it isn't going anywhere. Don't make this more complicated than it is.
I will add that these TTY GM bolts do have a history of snapping, and 80% of those that do were during removal, not install!
Old Feb 2, 2009 | 11:21 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I agree Dan. If its pinned and all the way seated, I wouldnt go any further.
Old Feb 2, 2009 | 11:31 AM
Blow Torch's Avatar
Blow Torch
Dang; I've made this complicated
The crank has been pinned, so the pulley SHOULDN'T spin.
I "BOTTOMED OUT" the pulley using the old bolt. (It was easy to feel when it bottomed on the crank throw)
If there is no longer a tenancy for the balancer to spin/slip, then, like you say, there should be no reason for the bolt to "loosen".
I do know one thing, I had the bolt in with locktight applied, and torqued to approx. 100* past 40lb, and I liked to have NEVER broke it loose (It was definilty harder to break loose than the original bolt!)
I don't mind taking the precaution of picking up another GM bolt for $5, but it does seem like overkill to pay $28 + shipping for a new bolt IF I don't need it.
(I should have taken more physics classes)
Old Feb 2, 2009 | 11:35 AM
iced98lx's Avatar
iced98lx
since you've backed the bolt out (and lucky makes a very valid point with the locktite) put a new bolt in and button this project up I used a stock GM one, not an ARP, but many people swear by the ARP stuff. It seems like quality to me, but then again I had an extra brand new GM one sitting here.
Old Feb 2, 2009 | 11:37 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
and invest in one of these. It makes wrenching soooo much easier.
they have them at Harbor Freight and most hardware stores.
