Vararam question
Old Jan 31, 2009 | 10:17 PM
Wickd1's Avatar
Wickd1
Default Vararam question
I just got finished with a 3hr install , everything seems to be fine, Do i need to disconnect the battery then drive it around to relearn , or can i just drive it around without disconnecting the battery first?
thanks
Old Jan 31, 2009 | 11:36 PM
c5blkvetteguy's Avatar
c5blkvetteguy
From what I remember reading...the battery should have been disconnected before you did the install.
Old Feb 1, 2009 | 01:49 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Guess I'm bad cause I just drove mine and it's was fine.
Old Feb 1, 2009 | 08:00 AM
rws.1's Avatar
rws.1
I copied and pasted this from another post.. there may be a few other variants on the forum you can search "PCM relearn"
The car will re-learn simply by driving it between 50-100 miles. Or, the actual way to do it more quickly, is the following procedure:
1) Insert key into ignition and turn to the “ON” position, but, DO NOT START THE ENGINE.
2) Open the engine compartment fuse box cover and remove the two 10 amp fuses from position numbers 16 & 23.
a) According to the manual there are two fuse boxes. Use the engine compartment fuse block for this procedure not the instrument panel fuse block.
b) Engine Compartment Fuse Block (correct one): 16 is Powertrain Control Module A and 23 is Powertrain Control Module B.
c) NOTE: Your DIC will now display “check” messages for ABS, etc… Do not worry as this is normal.
3) Turn the ignition key to the “OFF” position.
4) Return to the engine compartment fuse box and re-insert both 10 amp fuses for positions 16 & 23.
5a) Idle relearn for an M6:
1) Start the engine and allow the coolant temp to reach a minimum of 176 degrees F. Allow the engine to run at this minimum temperature for at least 5 minutes.
2) After the 176 degree, 5 minute minimum run, shut down the engine for a minimum of 30 seconds.
3) Restart the engine and check for DIC error codes (there should be none).
5b) Idle relearn for an A4: (different)
2) Allow the car to idle in DRIVE, with air ON and then OFF, for 5 minutes each, and then in NEUTRAL, with air ON and then OFF, for 5 minutes each.
3) Turn the car off for at least 30 seconds.
4) Restart the engine and check for DIC error codes (there should be none).
6) Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and temperature at the intake.
a) If error codes persist, repeat steps 1-7. Make sure fuses are properly inserted before repeating steps.
b) Do not deviate from the sequence outlined above. If you do, restart the sequence from scratch.
c) Steps 1-4 are also necessary if you ever disconnect your battery or lose power for any reason.
Old Feb 1, 2009 | 08:28 AM
Wickd1's Avatar
Wickd1
Thanks rws.1 Great info..
To Vararam question
