flex plate change
Old Feb 1, 2009 | 07:58 AM
c-5-steve's Avatar
c-5-steve
Default flex plate change
Is it a tough job to change the flex plate in a A4 car?
Can it be done with the vette on a set of ramps?
Will any Ls1 plate work?
Whats the cost of a new vs. used?
Old Feb 1, 2009 | 08:05 AM
rws.1's Avatar
rws.1
Do you mean the tunnel plate.
You need to take off the exhaust system.
You might want to be a bit higher than a set of ramps.
Two Forum vendors I have dealt with sell them.
CCA
http://www.customcorvetteaccessories...nelplates.html
and
Elite Engineerng
http://www.eliteengineeringusa.com/T...late_Link.html
Old Feb 1, 2009 | 10:40 AM
c-5-steve's Avatar
c-5-steve
I'm thinking my flywheel/flex plate has a crack in it, so thats why I'm asking the questions.
Old Feb 1, 2009 | 10:50 AM
clemsondave's Avatar
clemsondave
Funny you should bring that up. Not the vette, but I rebuilt my truck 6.0L yesterday and was going to put it back in today and found a crack in the flexplate..... I guess these are known to crack from time to time. Of course no one open on Sunday that has one.
What makes you think your's has a crack? I had no idea until I started cleaning it (out of the truck).
Old Feb 1, 2009 | 11:08 AM
c-5-steve's Avatar
c-5-steve
I'm getting a knocking noise that sounds like it's coming from deep in the engine while at a idle in drive with the brake on. Put it park and it goes away.
Old Feb 1, 2009 | 11:25 AM
Patches's Avatar
Patches
You have two flexplates - one is part of the flywheel assembly while the other is attached to the torque converter. Here are a couple of shots from my A4. Your '97 should be very similar if not exactly the same.
Front flexplate
From the '97 Service Manual:
The front flywheel, propshaft hub, and flexplate are balanced as an assembly. If service is required, the entire flywheel assembly should be replaced.
Rear flexplate
Here's a thread on my driveline upgrade a while back.
http://forums.corvetteforum.com/c5-g...mega-pics.html
To flex plate change
