LAPD 3.73 gears install
Old Jan 22, 2002 | 07:10 PM
mmorse's Avatar
mmorse
Default LAPD 3.73 gears install
Has anyone who purchased 3.73's from LAPD on the recent group purchase installed them yet? If so, what are your impressions? I'm particularly interested in Z06 owners that have gone to 3.73's. thanks
Old Jan 22, 2002 | 09:52 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: LAPD 3.73 gears install (mmorse)
I am on my second set and they are real nice on the street.. I lost 2 tenths in the 1/4 mile as well.. :)
Old Jan 22, 2002 | 10:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: LAPD 3.73 gears install (CHRIS NJ C5)
Why are you on your second set, was it a defect in the first set?
Now why did you lose .2 in the quarter????
Old Jan 22, 2002 | 10:32 PM
jschindler's Avatar
jschindler
I have driven and ridden in several Z06's. With their lower first gear, I can't imagine 3.73 gears. They are traction limited already, and wind first and second gears very quickly. Just my thoughts.
Old Jan 23, 2002 | 01:35 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I had my LAPD/GP 3.73s installed just last week in my 99 Coupe. As expected first and second gear pull tremendously. The surprise to me has been how 5h and sixth gear are now more than just overdrive.
I am nearly all setup fo rthe track this spring as I just purchased some 17X11 wheels for my drag radials. I should be able to lay down some of the power I now have.
Now that i have the 3.73s and am going to run it hard occassionally I will need bigger fuel injectors. I am heading up to CARTEK on 2/1 for the injectors and some more tuning on their on-site dyno.
Wish me luck!
Chuck
Old Jan 23, 2002 | 10:20 AM
Mad_Dog's Avatar
Mad_Dog
Default Re: LAPD 3.73 gears install (jschindler)
I agree with "jschindler" -- the first two gears would be very low on a Z06 with the 3.73s. Those low two first gears has alot to do with the 0-60 times on the Z06. The 3.73 might be a little much on a Z06 although I highly recommend them on a C5 -- I have them and love them.
Old Jan 24, 2002 | 05:42 PM
mmorse's Avatar
mmorse
Default Re: LAPD 3.73 gears install (Mad_Dog)
Man, not exactly glowing endorsements. I'm starting to regret buying the gears. Don't know if I want to put them in now. My Z is an everyday driver. How is the gas mileage affected?
Old Jan 24, 2002 | 07:50 PM
SilverStar's Avatar
SilverStar
If you want to unload them I could be interested. They would be perfect for an A4.
Old Jan 24, 2002 | 09:28 PM
boblackhardtop's Avatar
boblackhardtop
Wasn't there an earlier post comparing Z06, 3.90 from motive, 3.73 getrag gear. If I remember correctly the first 2 gear ratio of the Z is almost identical to the 3.90. Looks like you gonna spend most of your time rowing.
Old Jan 24, 2002 | 09:46 PM
Cruise-In V Veteran
Default Re: LAPD 3.73 gears install (wallstAL)
I snapped an output shaft on the first set.. When I said I lost 2 tenths, I meant lost from my previous time.. Better ET :) :)
Old Jan 24, 2002 | 09:55 PM
stuart3232's Avatar
stuart3232
how much are you guy's paying for the installation on the gear? does anyone know anyone near the atlanta area who could do the installation?
Old Jan 24, 2002 | 10:09 PM
Vette-Racer's Avatar
Vette-Racer
I want a set but even $1650.00 seems like a lot, of course if I could get $600 for the 3.42 then $1050 is doable. What will it cost to install a set ? :crazy:
Old Jan 24, 2002 | 10:35 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: LAPD 3.73 gears install (Vette-Racer)
Installation is about $450 with T/C around here! And you will need to reprogram the computer for an A4.
Old Jan 25, 2002 | 10:30 AM
ToplessTexan's Avatar
ToplessTexan
Was this from wheel hop or what?
Old Jan 25, 2002 | 09:58 PM
sunvet's Avatar
sunvet
You don't need the 3.73 gears on a Z06 since the gears in the transmission already closely resemble a 3.90 ratio as far as overal ratios are concerned.
Use the 3.90 diff with a stock MN6 to get the equivalent of a Z06.
Old Jan 26, 2002 | 01:19 AM
boblackhardtop
Default Re: LAPD 3.73 gears install (sunvet)
:yesnod: :yesnod: :yesnod:
Old Jan 26, 2002 | 01:49 AM
Cruise-In V Veteran
Default Re: LAPD 3.73 gears install (ToplessTexan)
No the track was just real stickey that night... :)
Old Jan 26, 2002 | 12:09 PM
ToplessTexan
Slicks, DR, runflats...?
I assume the new, beefier output shafts that have popped up fit this unit too... What do you anticipate being the weak link now?
[Modified by ToplessTexan, 10:13 AM 1/26/2002]
Old Jan 26, 2002 | 11:23 PM
Cruise-In V Veteran
I was running 275 drag radials.. The new output shafts are made out of a stronger metal.. The scary thing is the New weak link.. It should always be the tires.. easier said then done though.. the half shafts are pretty beefy.. my guess would be the clutch next or worst case the ring or pinion.. :eek:
To LAPD 3.73 gears install
