98 Window Problem help
Old Feb 1, 2009 | 02:36 PM
97C5owner's Avatar
97C5owner
Default 98 Window Problem help
My 98 recently developed a window gremlin. The window on the pass side won't roll down. When I press the button, I hear the relay click- and the headlights dim- but the window goes nowhere. Even if I push down on it while pressing the button- no joy. Am I looking at a new window motor, or a new door control module? If I do need a new motor, should I buy one with the track attached, or just the motor itself? Thanks to all in advance for the words of wisdom. -97C5
Old Feb 2, 2009 | 01:04 AM
kevin40zx's Avatar
kevin40zx
Did you try beating on the doorpanel with your fist? I've read this can be a quick temporary fix. Might narrow your problem down too.
Old Feb 2, 2009 | 01:27 AM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Just for the heck of it, open the door and look for the black loom that looks like an accordian. While pressing the down button, wiggle it and see if it'll go down. If that doesn't work, then beating on the door like kevin recommended won't hurt
Old Feb 2, 2009 | 10:30 AM
97C5owner's Avatar
97C5owner
Tried smacking her around a bit- no joy. I can still hear that relay in the door clicking and the voltage on the gauge drops, but shes not moving. Is that loom inside the door panel or between the door and the body of the car near the hinge?
Old Feb 2, 2009 | 10:46 AM
David426's Avatar
David426
Yhis is a common problem on many GM vehicles.. I had to take the door inside panel off of my chevy blazer and bang on the window motor with a rubber hammer while holding down the button.. Banging on the panel with my fist did not work.. Have not had any problems in 3 years.. They just get stuck
Old Feb 2, 2009 | 11:17 AM
B-ras's Avatar
B-ras
This is the only method that's worked for me. You need to pull the door panel, then the speaker. Through the speaker opening you can reach the motor housing. Hold the button while tapping a few times should free it. Unfortunately, it has been only a temporary fix for mine.
Info here: http://forums.corvetteforum.com/c5-g...w-problem.html
Old Feb 2, 2009 | 12:47 PM
red88L98convert's Avatar
red88L98convert
My 98 has done this twice since I've owned it. I just banged on the panel under the pull-bar a couple of times and voila!! The second time, I simply 'slammed' the door.
Slammed=closing door as hard as the schmuck with a honda accord would close his door!! LOL
Old Feb 2, 2009 | 01:33 PM
97C5owner's Avatar
97C5owner
Old Feb 2, 2009 | 02:18 PM
Bakersfield's Avatar
Bakersfield
Common problem. Read this:
Old Feb 2, 2009 | 04:29 PM
TEXHAWK0's Avatar
TEXHAWK0
You might be able to get it unstuck by tapping on it for a few times, but once they start to mess up, you will probably need to replace the whole regulator assembly.
I have already replaced both on my 04, and they are still working.
The cables could be a problem, but most of the time the motor quits before the cables wear out.
Weak relays in the door control module could keep the windows from working, but on both of mine, the new regulator assembly fixed the problem. If you can hear the relay click, chances are that power is getting to the motor and it is just in a dead spot on the rotor. I have had that happen on starter motors also. If the engine tends to stop in the same place on the rotor a lot, eventually a dead spot will develop. Jarring the started motor with a hammer will move it just enough to pick up power again.
To 98 Window Problem help
