Name This Part...
Old Feb 2, 2009 | 06:53 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Even you, Lucky. But because of your first reply, you must pull on this finger. Ahh, tnx!
I'm sure I'll see him before you do so just send me that finger and I'll have him pull it for ya...
Old Feb 2, 2009 | 08:12 PM
vsocks1's Avatar
vsocks1
Originally Posted by ncvettes
That's what happened to mine, but have since removed the Pfadt tranny mount due to vibratory displeasure, so to speak.
Thanks for the info people, You've been helpful as always. Even you, Lucky. But because of your first reply, you must pull on this finger. Ahh, tnx!
No noise from mine!
Old Feb 2, 2009 | 09:28 PM
lucky131969's Avatar
lucky131969
Originally Posted by LoneStarFRC
Ummm, what page dat be on? I have the 1999 shop manual.
It's in the "Rear Drive Axle" section under "Axle vibration damper replacement".
Old Feb 2, 2009 | 09:31 PM
lucky131969
I was trying the reverse logic thing based on your question: ... "should I put this thing back on?"
Old Feb 3, 2009 | 01:34 AM
LoneStarFRC's Avatar
LoneStarFRC
Ugh. Generous Motors screws up again. I had to drill down into the actual Removal/Installation itself (on pg 4-107) to find any reference to torque values for those two bolts. Wadda pain in the bonzolla.
If you look at the torque values table on pg 4-97 (commonly shown at the beginning of each of the various sections throughout the shop manual) where the numbers - both Metric and English are listed - for the subsequent components under repair, the torque value for this item is NOT listed.
This isn't the first time I have come across a screw-up in the shop manual. Omitting a torque value from a "Fastener Tightening Specifications" table is minor. Take a look at "Engine Controls - 5.7L" on pg 6-482. There you will find an external LH "view" of the trans-axle assy., illustrating the location of three exterior attached components. Tell me if you see anything strange? I realize of course that a different year manual or "interweb" version may not have the exact same pg #, etc, or that possibly the matter was corrected in later manuals, but try anyway.
The worst screw-up I have come across was an incorrect torque value listing for something that would be a slam-dunk guaranteed stripped-bolt/damaged thread. Don't recall the actual item, but suffice to say these "bibles" cannot be taken as ABSOLUTE gospel.
Last edited by LoneStarFRC; Feb 3, 2009 at 02:00 AM. Reason: terminology correction
Old Feb 3, 2009 | 01:45 AM
lucky131969
... but suffice to say these "bibles" cannot be taken as ABSOLUTE gospel.
True.....but then again....I've never seen anyone walk on water or feed 3,000 people with a loaf of bread and a fish either...
Old Feb 3, 2009 | 02:10 AM
LoneStarFRC
One of the things I have learned about these Helms GM approved shop manuals is that despite their value, which is considerable, they are also chocked full of mistakes too and that anyone, HAS to think about what their doing vs. the "manuals" explanation. Most times, the manual is right but not always. The proof-reading SUX. Cost cutting and/or laziness is my guess.
Hell, I'm even seeing the EXACT SAME drawing numbers in the 2006 manual (that I also have) that show TWO slots in the driver's side fuel rail covers for the '97 to '98 fuel/return lines. Also a couple illustrations still using C5 components illustrations of the Evap Purge Solenoid. Gee, who'da thought that the 6.2L and the 7.0L still used the same C5 components of the same design? NOT!!
Old Mar 30, 2011 | 10:46 AM
Schoolteacher's Avatar
Schoolteacher
I need one of these dampners, does anyone have the part number?
