Easy out (seat) not working!
Old Jan 22, 2002 | 09:31 PM
TOPGUN9's Avatar
TOPGUN9
Default Easy out (seat) not working!
When I pull the key out of the ignition, the easy out feature where the seat goes all the way back doesn't work. The easy out feature is activated, and when I press the memory button, my seat adjusts to it's preset.It just won't retract when the key is pulled. Any ideas??
Old Jan 23, 2002 | 01:40 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: Easy out (seat) not working! (TOPGUN9)
I have your problem and some others with my seat. Has been to dealer once without fix.
What I have noticed now is that whenever my seat does not act correctly if I rock in the seat and retry the function I was attempting it them works.
Sounds crazy but this has been happeing in my car for months now, i am used to it.
Probably some short or loose connection under the seat but I do not want to go through seat removal at this point.
Good Luck
Old Jan 23, 2002 | 01:03 PM
Innocent Bystander's Avatar
Innocent Bystander
There's a contact inside the ignition switch that tells the seat when the key is removed. If it's stuck to the "key in" position, pulling the key won't trigger the easy exit function. However, you'll also her the "key in" reminder chime when you open the door. So if you hear the chime with the key pulled, the problems likely in the ignition switch, otherwise, you might need to check some wiring between the ignition switch and the seat controller.
Old Jan 23, 2002 | 01:23 PM
Cam69ss's Avatar
Cam69ss
There was an article about this is a recent Corvette Quarterly article. Make sure that you are opening the car via the fob and that it has your presents in memory. If you do not use the fob, the car will not know to put the seat in the way back position.
Anyone correct me it my memory is wrong.
Hope that helps
Old Jan 23, 2002 | 01:46 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Easy out (Cam69ss)
There were some changes to the easy entry "logic" for 2001, but on all years I didn't think you needed to do anything, to make the seat retract, except take the key out of the ignition- no fob use required.
Fob use IS required to get the memory settings when you INSERT the key, or just tap the appropriate button.
To Easy out (seat) not working!
