C6 Z06 stabilizer bars and shocks...
||--Genuine GM C6Z51 Sway Bar Kit--||
10323434 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 (2) – Front stabilizer insulators
15241135 (2) – Rear stabilizer insulators
Complete kit front and rear is 192.05
Use part number c6z51bars on our website under Chevrolet make.
These sway bars do fit any C5 without any modifications.
This kit does not come with metal end links. If you want to add metal end links use part number 25932329 for $24.49 each.
GM has now updated all C5-C6 end links to the 2009 version.
||--Genuine GM 2008 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) 236.28
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on C5’s without modification.
Link to the site?
I hope this helps.
Roger T
Gene: I will also be purchasing C6Z51 bars from you in the summer... My 2003 has metal end links already so I don't need to purchase new ones, right?
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Take notes. There is something to be learned here.
I hope this helps.
Roger T
Show me where I said "uncontrollable"... The C6Z rear bar is set up for a car with 12" wide rear wheels which a C5 does not have. I am not alone in this theory.
That being said, I'm sure people have enjoyed success with all sorts of different setups.
I have taken lots of "notes" since joining this forum.
[/QMr TT,
Show me where I said you said " uncontrollable ." What I correctly said was " ....by your logic... " the T1 cars would be uncontrollable.
C6 Z06 rear sway bars are 28.0 mm.
C5 T1 rear sway bars are 27.5 mm.
A differance of .5 mm. A mute point
Roger T
C5 Base: 23 mm front / 19.1 mm rear (1.20)
C5 Z51: 28.6 mm front / 23.6 mm rear (1.21)
C5 Z06: 30.0 mm front / 23.6 mm rear (1.27)
C6 Z51: 31 mm front / 25.4 mm rear (1.22)
C5 T1: 38.4 mm front / 27.5 mm rear (1.40)
C6 Z06: 31 mm-front / 28.8 mm rear (1.08)
Too big of a rear bar with too small of a front bar will decrease available traction when exiting corners and cause you to oversteer. The C6Z bar has the lowest front:rear ratio, presumably because the C6Z has quite wide rear tires, so the engineers have more inherent grip to work with at the rear and can afford to decouple the rear a bit and still maintain a similar balance to the other models. The T1s are on the opposite end of the C6Zs and seem to be the most aggressive and best suited for auto-x, thus explaining why your friends like them. All the other setups, including the C6Z51, will preserve the neutrality of a base suspension C5 but will reduce roll. That is why people recommend C6Z51 sways over the C6Z06 sways on a C5.
I never said, implied, or used logic to state that C6Z sways or a T1 setup will make a C5 uncontrollable. I am just providing a counter to your assertion that C6Z bars will not change the handling balance of a C5. If you ran the same size tires as a C6Z on a C5, then I would agree with you, and could see recommending C6Z sways over anything else. But if you're going to run 245/275 or 265/295 tires I would think that the C6Z51s would be your best bet and that C6Z bars will be too much in the rear.
The current C6 Z51 or Z06 makes more sense for street/autocrossing.
T-1 Performance Parts are hugely expensive for most of us.
I hope this is helpfull.
Roger T
