dropping the cradle
Old Feb 2, 2009 | 07:45 PM
Blow Torch's Avatar
Blow Torch
Default dropping the cradle
I CAN NOT get my steering rack back in! I have actually got it to a point I can't even move it. (I consider myself a competent mechanic, but I'm not worth a darn at PUZZLES!!) SO:
Can I drop just one side of the cradle enough to give me a little room, or do I have to drop everything? If so, what is the proper procedure?
2. Do I have to have an alignment after I drop it?
Been working on cars (corvettes mostly) for 30 years, and this is the most frustrated I've been in a while
Old Feb 2, 2009 | 07:47 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
The cradle does have to be dropped some. You need to loosen but not remove the four mounting bolts. You can use a 2x4 to wedge it down on the passenger side. Then you should have clearance.
Old Feb 2, 2009 | 08:35 PM
Blow Torch's Avatar
Blow Torch
I loosened the front passenger side bolt just a little (1/2" maybe), to try and pry it down fo rsome clearence, but didn't have enough "hands" to hold everything. I have my jack stands under the cradle holding up the car. Do I need to move them to the side of the car so the cradle will drop easier?
Will I have to have an alignment?
Old Feb 2, 2009 | 08:59 PM
Mark C5's Avatar
Mark C5
I'd move the jack stands for sure. If you didn't alter the tie rod ends you probably don't need an alignment, but it couldn't hurt. Also, you need to loosen all the cradle bolts.
Old Feb 2, 2009 | 09:24 PM
lucky131969's Avatar
lucky131969
I would take a break or get help from a local forum member. Dropping the cradle is not necessary for this task.
Old Feb 2, 2009 | 09:33 PM
Mark C5's Avatar
Mark C5
Service manual must be in error.
Old Feb 2, 2009 | 09:42 PM
lucky131969
There is a vast departure between dropping the cradle and loosening the mount nuts.
Old Feb 2, 2009 | 09:43 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I agree, its not necessary to re-install the rack.
Take a break bro, and come back when you cool down.
I get frustrated sometimes and after I cool down a bit, it goes in nice and smooth
Old Feb 2, 2009 | 09:51 PM
Mark C5's Avatar
Mark C5
The reason for loosening the cradle (crossmember) bolts is to allow the cradle to drop. Notice I said loosen not remove. There is a vast departure between dropping the cradle and removing it.
Old Feb 2, 2009 | 09:58 PM
lucky131969
Yeah, I know...and I didn't respond to you in the first place...I responded to the OP's original post about dropping the cradle. I try to be careful with terminology, because for whatever reason, some folks just refuse to use a service manual. To some guys on this forum, if you say "drop the cradle"...they will do just that.
Old Feb 2, 2009 | 10:07 PM
GreyGT-C's Avatar
GreyGT-C
i've had my PS rack out 3 times and have never even loosened the cradle bolts. Are you pulling the rack from the top of the car or below?
Old Feb 3, 2009 | 07:39 AM
Blow Torch's Avatar
Blow Torch
I pulled the rack out of the passenger side. I haven't removed the fans or radiator, but they haven't really been in the way.
The issue I'm having is the steering gear is getting tangled up in the ac hoses and the passenger side rack mounting ears. I absolutely can't get it past them. If I could get the rack to tilt a little more, maybe I can maneuver it over that mounting tab. That was the reason for wondering about dropping the cradle.
The reason this is stumping me, is that I help a wrench in Fla. do the H/C on the car about 2 1/2 years ago, and I help HIM remove and reinstall the rack, and we just didn' have this much trouble. Now it is just me, with my wife trying to help
It would be great to have someone help me out, but there are only a couple of guys in the entire town with modded Vettes, and they paid for their work to be done All of my friends play golf, they don't work on cars
Old Feb 3, 2009 | 10:11 AM
Sinister-one's Avatar
Sinister-one
Can you say................................. DEEP POCKETS !!
Old Feb 3, 2009 | 12:04 PM
GreyGT-C's Avatar
GreyGT-C
from what i can remember without going out to the garage and looking at mine is...
come in from the top. and stick the right side of the rack out thru the passenger wheelwell with it rotated to where the steering column attachment is pointed forward and lower it down to where it's horizontal... now slide the rack over to where the steering column attachment is just past the crank pulley. You should be able to start rotating it at this point. It's gonna be a move a hair to the drivers side and rotate a hair, and repeat several times but it should drop right back in after a few times of this.
Too bad you're not local. Hope this helps.
Old Feb 3, 2009 | 12:10 PM
Blow Torch's Avatar
Blow Torch
If I come in from the top, will I be able to clear the traction control and power steering reservoir?
Old Feb 3, 2009 | 02:23 PM
GreyGT-C's Avatar
GreyGT-C
I had the radiator out of mine everytime.. i removed the mounting bracket for the traction control do-hicky and that gave me enough room to move the traction control box forward out of my way. I think i also had the PS reservoir removed also.
To dropping the cradle
