Changed battery, threw some codes.
Old Feb 3, 2009 | 08:00 PM
Kale's Avatar
Kale
Default Changed battery, threw some codes.
I changed the battery last night.
OK this morning, but on the commute home I got:
(2004 LS1 manual)
Oddly, they were all history codes. Which I thought they shouldn't be if I have a CEL?
B2592 Column Lock/Unlock Drive(B)
Also, I saw "Pull key wait 10 seconds" briefly after I got home and put the car in ACC mode to check codes.
I should note that I DO have the aftermarket column lock bypass mod. Do these fail?
P0803 1-4 Upshift Solenoid Control Circuit.
-I have the skipshift eliminator installed.
LDCM B2282 - Battery #1 Fault - I'm guessing this popped up as I was tightening the posts down.
I reset all codes. Is there anything I should be concerned about, or is this typical of a battery change?
FWIW, the car ran perfectly.
Old Feb 3, 2009 | 08:05 PM
lp2k's Avatar
lp2k
yes its typical happened to me
Old Feb 4, 2009 | 01:09 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Very common issue.. Just clear all the codes and monitor frequently to see if there really is an issue. You know that you can read DTC while your driving>> Just be careful and dont wreck while doing it.
BC
To Changed battery, threw some codes.
