fuel sender problem
Old Feb 5, 2009 | 11:16 AM
white top's Avatar
white top
Default fuel sender problem
after 9 years fuel gage dropped to zero shortly after filling the tank and I got the check gages light. Presently running tectron thru the tank but no luck so far. Anyone know apx cost of RH and LH fuel senders and cost to install.
TIA Jerry
Old Feb 5, 2009 | 12:17 PM
'02magredZ51's Avatar
'02magredZ51
Jerry,
You mentioned running techron, but is it the same gas you filled up with? The senders in these are VERY sensitive to the sulpher level in the fuel. If you do a search there are several threads on it. I had the same problem in CO and again in England because of cheaply manufactured fuel. A full tank of super from Shell/Exxon/Mobile/Texaco and a bottle of STP fuel injection sytem cleaner (white bottle, red label) did the trick for me. See if it doesn't rebound.
Also, have you reset the codes?
Good luck.
Old Feb 5, 2009 | 12:56 PM
timemender's Avatar
timemender
Jerry –
May take some time for the Techron PLUS to clean the deposits, if those deposits are heavy. Add Techron PLUS for at least three or four tank fillings if need be, before buying expensive parts & labor.
Techron PLUS is a quality product that should do the job of cleaning the deposits.
Adding Techron a couple of times a year should keep the deposits at bay.
Also reset the codes as advised in the above post.
EDIT 2-10-2009 1:19pm -
See this related thread –
(sometimes it takes time for the deposits to dissolve) be patient and allow time as I stated above
http://forums.corvetteforum.com/c5-t...post1568889119
Old Feb 10, 2009 | 10:52 AM
'02magredZ51
I think I hear a cat being murdered... but...
Any luck, Jerry?
Old Feb 10, 2009 | 03:12 PM
white top's Avatar
white top
thanks for replies no luck yet. wonder if I should be concerned about running out of gas,i.e.is fuel being transferred from RH to LH tank/
Jerry
To fuel sender problem
