Knock sensor
Old Feb 8, 2009 | 09:22 AM
lysy_222's Avatar
lysy_222
Default Knock sensor
I've got a question to you about Knock sensor, namely what is its purpose, and where is it located ?
Old Feb 8, 2009 | 10:09 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The knock sensor is a microphone.. two of them. They listen for pinging from using too low of octane gas. If knocking/pinging is heard, the PCM will get its spark advance information from a low octane table as opposed to the normal.
They are located under the intake manifold. If you picture an old valley-pan, its sort of like that but not quite. Anyway, its easy to get too.
Old Feb 14, 2009 | 02:44 PM
lysy_222's Avatar
lysy_222
Thanks dgrant3830
Old Feb 14, 2009 | 03:51 PM
dougbfresh's Avatar
dougbfresh
Not easy to get to, you have to remove the intake manifold. The old sensors were on the OUTSIDE of the block-MOSTLY east to get to (not all). There are 2 inside the LSX blocks for more accuracy ( A front and rear sensor and a connector to the back of the block).
Old Feb 14, 2009 | 03:57 PM
lucky131969's Avatar
lucky131969
Only LS1/LS6. LS2(2005) moved the knock sensors to the outside of the block(left and right).
Old Feb 14, 2009 | 03:59 PM
dougbfresh's Avatar
dougbfresh
Wonder about the LS3 and 7.
Old Feb 14, 2009 | 04:15 PM
lucky131969
same as ls2
Old Feb 14, 2009 | 04:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There under the two rubber plugs. The factory plugs are NOT sealed very well and if the engine is hosed off, the wells will fill with water and destroy the sensor/connectors.
Old Feb 18, 2009 | 07:31 AM
lysy_222's Avatar
lysy_222
Thanks evryone for helping me.
Now I know everything about Knock sensor what I need
Old Feb 18, 2009 | 10:47 AM
dgrant3830's Avatar
dgrant3830
It took me about 30 minutes to remove the intake and the same to put it back on. Really an easy thing to do.
To Knock sensor
