raptor shift light install
Old Feb 9, 2009 | 01:50 PM
Blue Lightening's Avatar
Blue Lightening
Default raptor shift light install
Anyone have any pictures of where they installed their Raptor shift light? Mine just arrived today and I am looking for advice on where to mount it. Would also appreciate any installation advice on where they tied in the wires into etc.
Old Feb 9, 2009 | 02:02 PM
vsocks1's Avatar
vsocks1
Old Feb 9, 2009 | 02:03 PM
bumble-z's Avatar
bumble-z
Default EZ as 123
Go to the very top right of the tech page hit the search this forum, type in shift light installation. Thats what I used to install mine. good luck.
Old Feb 9, 2009 | 04:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Where I mounted mine...
As for finding the white tach signal wire, this thread was of tremendous help.
http://forums.corvetteforum.com/c5-t...-big-pics.html
Besides the great pics in post 1, also read post 20 in that thread for a good tip on isolating the correct white wire. That's how I did it, and it worked great!
Old Feb 9, 2009 | 06:06 PM
Blue Lightening
Thanks for your help with this. I searched the archives and didn't find much. Question...How bright are the lights on the Raptor at night in that position?
Old Feb 9, 2009 | 06:32 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
As I pictured it, with the plastic "night shade" cover over the LEDs, it's very visible at night.
Take the cover off, and it's bright enough to notice even with the top off the car in direct sunlight. If you used it like that at night, it would probably illuminate most of the interior when it lit up. Don't let it's little size fool you, it is a very intense and bright cluster of LEDs.
Might be hard to tell from that pic, but it is angled and pointing directly at me when sitting in the seat. Most others I know that use them in the A-pillar flush-mounted them in the little blank area next to one of the gauges. Basically pointed at the same angle, but all you see is the face of it doing it that way.
Since my car kinda has a chrome/yellow theme going on throughout, I decided to order the Raptor in the chrome housing and leave it exposed.
Old Feb 9, 2009 | 06:37 PM
Patches's Avatar
Patches
Installed mine in a mount I designed. It is very bright - you will not miss it at night time. I tied in at the footwell fuse panel area where the harness comes in through the firewall.
Old Feb 9, 2009 | 06:54 PM
warren s's Avatar
warren s
Old Feb 10, 2009 | 11:44 PM
Smokem02's Avatar
Smokem02
A lot of the 05+ mustangs are putting them in the ac duct closest to the driver. It is a fairly easy install and VERY stealth if you are going for the sleeper look cause you never see it until it flares up. Would like to due that in the vette but logistically dont think that will be possible.
Old Feb 20, 2009 | 08:35 PM
Blue Lightening
The post of tapping into the wire under the instrument pannel looked good but isn't working for me...
For lack of better words I am having a heck of a problem figuring out where to tie in the tack pulse wire. I don't know how this can be done unless you are tripple fingered and double jointed with an enimic problem and have the ability to cut a wire somewhere that you can feel but not see. Has anyone else done this? I could use some advice.
Norm
Old Feb 20, 2009 | 09:24 PM
warren s's Avatar
warren s
Well it wasnt easy, and I did cut a wire in error and have to solder it back. There are 2 wire bundles, one is closer to the left , underneath the foglight / hatch release switch area.
not hardest job by far.
Old Feb 21, 2009 | 02:37 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
Did you remove the knee bolster? That should give good access. You can also access that same wiring bundle a few inches forward without removing the bolster,and the wires aren't covered. It's where the bundle joins a larger bundle.
Old Feb 21, 2009 | 06:59 PM
Blue Lightening
Got it done. Damn it looks great.
I had one heck of a time getting to that bundle. Had to remove the stuff LPE tied in there. The wire bundle didn't have to seem the same play in the wires that were in the pictures.
Ended up going to Auto Zone and buying a soldering gun with a long pointed nose on it. Used a razor blade to scrape the insulation off of the wire then soldered it.
Once I got that done everything else was easy.
Thanks everyone for your help. Now that I am done I feel a sense of accomplishment....Damn it looks good...It also works to boot.
Old Feb 21, 2009 | 07:42 PM
vsocks1's Avatar
vsocks1
Good! Where did you mount it?
Old Feb 22, 2009 | 05:25 PM
Blue Lightening
Photos of this weekends project. Thanks everyone for their help and advice.
Norm
Old Feb 22, 2009 | 05:34 PM
vsocks1's Avatar
vsocks1
Looks good! Same line lock I have also.
Did you get the dual shift light with the launch rpm too?
Old Feb 22, 2009 | 07:07 PM
Blue Lightening
I just got the single shift light. I was expecting the install of the line lock to be the difficult part with the shift light being the easy task.
I was surprised how easy the line lock was to install but had one heck of a time with getting to the tack out wire on the shift light but it all worked out great in the end.
To raptor shift light install
Old Apr 4, 2009 | 06:10 PM
02SCvette's Avatar
02SCvette
I've read a lot of posts on the Raptor install and I didn't see anyone ask about pulling the lower panel off to get to the wires. I removed the 2 screws from the base of it and started pulling. I can see there are some hidden push pins but are there any hidden screws that have to come out before I break something? I didn't want to start pulling too hard and snap something.
Thanks guys!
Old Apr 4, 2009 | 06:22 PM
warren s's Avatar
warren s
take a look at the link below - its for taking out the insturment panel but shows some hidden screws.
http://www.vetteessentials.com/instr...zel_howto.html
Old Apr 4, 2009 | 08:29 PM
02SCvette's Avatar
02SCvette
Thanks! That shows me everything that I needed.
