Water pump failed again?
Old Feb 9, 2009 | 03:22 PM
xizor's Avatar
xizor
Default Water pump failed again?
I have a 2001 Coupe with 92,000 miles on it. I purchased the car at 75k, and replaced the water pump and belt myself at about 85k 2 years ago due to leaking fluid and squealing belt symptoms, and everything was good until this fall when it came back again.
Is it somewhat normal for the water pump to fail within 10k miles or do I have bad luck? Is there anything that could be causing the water pumps to fail? I don't want to burn up a 3rd one.
Old Feb 9, 2009 | 03:28 PM
TEXHAWK0's Avatar
TEXHAWK0
If your coolant is clean and you did not run the pump dry, there is not much you could have done to make a pump fail that quickly.
Was the pump you installed new or rebuilt? I hope you installed a new pump.
Old Feb 9, 2009 | 03:31 PM
xizor's Avatar
xizor
The pump was new. The only thing I can think of, is back in Dec. the pump did run dry/low when the upper radiator hose (previous owner aftermarket coupler ) separated from the radiator under heavy acceleration and pumped fluid everywhere... but the weeping/squealing was back long before that happened.
Old Feb 9, 2009 | 03:35 PM
WAGONGUY's Avatar
WAGONGUY
What kind of job is it to replace a water pump? getting ready to have my balancer replaced. should I have the pump replaced at this time or can I just wait till I have problems. Car has 43,000 miles. Does the rack need to come loose for the water pump?
thanxxxx
Old Feb 9, 2009 | 03:41 PM
xizor's Avatar
xizor
thanxxxx
I thought it was pretty easy, everything can be done from above inside the hood. The worst part is emptying the fluid, it gets everywhere. Might be harder if you have a pre-2001 since they have a paper gasket. I wouldn't replace unless you have a problem however.
Old Feb 9, 2009 | 06:21 PM
Bakersfield's Avatar
Bakersfield
Reminds me back in the late 70's when I had a 72 Dodge Challenger. It went through 3 "re-manufactured" water pumps before I bought a new one from the Dodge dealer and my water pump problems went away. If your buying water pumps from Pep Boys, Auto Zone or other discount parts stores, DON'T. It ain't worth your labor and time replacing them.
Old Feb 9, 2009 | 06:53 PM
KCvetteowner's Avatar
KCvetteowner
Buy an LS3 water pump!!!! It requires a different/standard thermostat and thermostat housing. The pulley "bell" is smaller on the LS3, less rotating mass. The original water pumps on the LS1/LS6s were shared among several different cars with different belt layouts and that is why the pulley "bell" is so big. I've been running an LS3 water pump on my 418ci LS3 motor and no problems with 3500 miles on it.
Old Feb 9, 2009 | 08:50 PM
kevin40zx's Avatar
kevin40zx
Yep, I spent almost as much time trying to scrape all the old gasket off as I did with the removal/installation.
Old Feb 9, 2009 | 10:19 PM
ericdwong's Avatar
ericdwong
Me too, that was a PITA- also do not route the throttle body coolant line underneath the main radiator house- it will contact the water pump bell and chew through it. Don't ask me how I know..
But- to the OP, that seems an awefully low mileage to need another one. My OEM one lasted til 135k or so, and I only replaced it cause I saw a little bit of seeping. Figured better to be safe than sorry.
Old Feb 9, 2009 | 10:44 PM
LoneStarFRC's Avatar
LoneStarFRC
.............Might be harder if you have a pre-2001 since they have a paper gasket......
Paper in '97s and '98s only. The change to the newer design was made in '99, plus the replacement gaskets from GM are the later design too.
Old Feb 9, 2009 | 11:57 PM
happiedazs's Avatar
happiedazs
Make sure the belt fits squarely in the pulley --- if it's cockeyed for some reason the angular tension can cause water pumps to fail quickly
Old Feb 10, 2009 | 09:09 AM
jimcork1's Avatar
jimcork1
Interesting. Let's see if I understand. I have a 99 bought new in 99.
The LS3 pump will exact fit and there is a new thermostat for this that does not have the thermostat built into the hose assembly?
The water pump pulley is smaller and the stock 99 belt will fit with a little more slack? PITA to replace mine due to being so short.
IF this is correct, do you happen to have any part numbers. thanks vettdvr
I have 85000 on my 99 and will probably need a water pump soon.
My water pump has seen some pretty high rpm's
To Water pump failed again?
