FAST install ?
Old Feb 9, 2009 | 03:49 PM
FRCVETTE99's Avatar
FRCVETTE99
Default FAST install ?
Just a quick question about installing FAST intake manifold . Do I need to change the coolant lines like with LS6 intake install on 99 LS1 ???
Old Feb 9, 2009 | 03:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I can't remember what the bottom of the FAST looks like!
So if it is the same as the LS1 (Raised so the coolant line can go under) then you'll be good.
If it is flat like the LS6 Manifold then you will need to get the new lines for the coolant tubes.
Do you have a picture of the bottom of the FAST near you? can you post one?
If not then you will need to do a side by side comparison! Here is a pic to the LS1 How To on swapping from a LS1 to the LS6 - it will show the two different bottoms, so this should give a general idea
Hope this helps a little.
http://www.ls1howto.com/index.php?article=5
Thanks,Matt
Old Feb 9, 2009 | 04:00 PM
FRCVETTE99's Avatar
FRCVETTE99
thanks Matt , found it on FAST's website finally . And for the record , you DO have to change them to the newer style , 2 plugs at rear , and single cross over in front !
Old Feb 9, 2009 | 04:08 PM
madmatt9471
PERFECT!
You might want to post the link for others future use I'd like it too
Just goes to show you that we learn something new every day!
Hey! Keep us posted on your progress and throw a few finished pics in there and maybe even some along the way pics
Thanks,Matt
To FAST install ?
