What is normal operating temperature?
Old Feb 10, 2009 | 12:29 AM
stunter steve's Avatar
stunter steve
Default What is normal operating temperature?
Does anyone know what the normal operating temperature is for a 2000 C5?? I changed the thermostat but it seems to run a bit hot in traffic....Thanks.
Old Feb 10, 2009 | 12:34 AM
lucky131969's Avatar
lucky131969
Ok, I'll bite.....define "a bit hot".............
Old Feb 10, 2009 | 01:50 AM
Last C5's Avatar
Last C5
Normal operating temperature is 192.7 degrees. Now that you've read it on the web, it's got to be true. Some where between 190 and 210 and you're probably fine.
Old Feb 10, 2009 | 03:48 AM
David426's Avatar
David426
You need to define " a bit hot" 230 degrees in the summer, with a/c on and 90 degrees outside temp is normal in stop and go traffic.. 200-210 degrees in winter..
Old Feb 10, 2009 | 07:05 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The best way to take advantage of a thermostat is to get a lower temp and have the fans ON/OFF temps changed to a lower setting - therefore getting lower running temps
You can do this either by a Handheld tuner or having a Shop do the adjustments - it is worth it
Thanks,Matt
Old Feb 10, 2009 | 07:13 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Open road: 190 to 196
In traffic: 226 to 230 before the fans kick in.
Old Feb 10, 2009 | 08:07 AM
99 vett babycar's Avatar
99 vett babycar
do a search for "sweet spot" a tread by EvilTwin - one of the few guys who knows what he's talking about.
To What is normal operating temperature?
