Performance Bang for the Buck
Old Feb 13, 2009 | 08:44 PM
intoc6s's Avatar
intoc6s
Originally Posted by 4DRUSH
And your 1/4 mile time is ????
(best to build your drive trane first before adding HP)
And your IQ is????????
Old Feb 13, 2009 | 08:53 PM
intoc6s's Avatar
intoc6s
If he was going to go to 3.42 gears and he has 3.15- don t you think the money would be better spent on something else than that small increase in acceleration that 3.42 s give. And i didn t say not to "Build his drivetrain", that s a given, Cocky! Not everyone wants to run 9s and run out of gear at 1320 ft.!(as i assume you do)
Old Feb 13, 2009 | 09:20 PM
4DRUSH's Avatar
4DRUSH
I would go with a Yank SS3800 & 3:73 gears for your current mods.
I never said the op should go with 3:42's. Yes I agree going from 3:15's to 3:42's aren't worth it. But staying with 3:15's isn't going to help the op reach his goal of running in the 11's without a power adder.
Hit a soft spot. Chill fellow Corvette bro.
Old Feb 13, 2009 | 10:22 PM
jimish's Avatar
jimish
Correct, I wouldn't spend money going to 3.42's. My initial question was going for 4.11 gears. Arguments against that include my short tires, running out of revs in third and shifting up to fourth on nitrous, and getting the car to launch in its power band. I agree I'll leave the 3.15 alone and go for a better converter. See how the car hooks and goes, then try a small 100-150 shot to get it into the 10's.
Old Feb 13, 2009 | 11:24 PM
zoomz's Avatar
zoomz
I picked up 7/10th by going to a 3.42/3200 over the stock converter and the 3.15 gear and still get great drivability with the car .
When i spray the car with a 150 off the line, the converter flashes to 35-3600 rpms and it runs out at 6600 rpm in 3rd at 10.50@134 .
If you can find a good 3.42 chunk to put in with the bigger stall i would because it really makes the car come alive around town and off the line .
Old Feb 14, 2009 | 12:12 PM
intoc6s's Avatar
intoc6s
Yeah, it ll no longer be a soft spot after i take it to the track..the first day i finished my forged 427/Spec clutch/new tranny& diff install, i was so excited that i literally floored it within the first 20ft!! Needless to say, the dyno showed a slipping clutch and it has only gotten so bad that i couldn t hardly climb a hill on the highway without it "downshifting"(its a 6spd), especially in higher gears. Well i just installed a new clutch a couple of days ago and AFTER i break in this clutch ill dyno-tune it and then get it ready for the track. I already have skinnys for the front and Mickeys for the back.....And i ran the line for my nitrous bottle. So, i hope around 800rwhp(estimated-600na+200nitrs) will get me down the track pretty fast. My only real thing that i HAD to do was install 3.15s+DTE brace, cause i like topend brawls the best! 4DRush- You re the man on 1/4 mile, i have no arguments here! Nevermind my Bipolar outbursts!! (its like having Turrets syndrome) Peace-Jason
Old Feb 14, 2009 | 12:14 PM
jimish's Avatar
jimish
zoomz, thats close enough. A good converter with my shorter tires and 3.15 is almost the same as you have. Then a small shot and see what it does.
Old Feb 14, 2009 | 02:08 PM
zoomz's Avatar
zoomz
Yea , now that im running a 400 shot i had to get carbon fiber clutches and bigger noids for the 3/4 gear clutches so i could spray in overdrive .
I will probley get a 315 gear next time i need to freashen up the tranny .
Old Feb 14, 2009 | 04:14 PM
tiojames's Avatar
tiojames
Thats what I was thinking. Also, its easier to drop the differential than changing the converter
I don't know if you have looked, but the tranny and converter come down with the diff. Labor to change the converter and new fluid run $100 or less with the drive train dropped. By the way, your 3:15s are worth about what you would pay for a set of used 3:42s which will be a low enough gear unless you plan on mostly drag racing your car.
