Chains on a C5 ??
Old Feb 16, 2009 | 01:25 AM
ColeTrain'sC5's Avatar
ColeTrain'sC5
Rent a truck
Old Feb 16, 2009 | 01:46 PM
427435's Avatar
427435
Here's a photo I took when I first got my C5. When I was done, I couldn't drive the C5 back into the garage. It just sat there and spun a wheel. The C2 (on badly worn old radials) drove off fine. The conclusion I came to was that the stock Goodyear runflats were useless on snow (and probably on cold roads).
You could easily end up wrecking your car if it doesn't have (at least) all season tires.
Old Feb 16, 2009 | 05:24 PM
ColeTrain'sC5
Z rated tires are HORRIBLE in the snow
Old Feb 18, 2009 | 01:37 AM
8NT SLOW's Avatar
8NT SLOW
St. Jude Donor '09
OK, time for an update, I got sick and didn't make it out of California.
I had to turn around on Monday, go home, and I am writing this from bed.
Oh well, the best laid plans.
Thanks for all the advice.
Bill
Old Feb 18, 2009 | 11:56 PM
Bill Dearborn's Avatar
Bill Dearborn
By the way I didn't see your thread until after you said you were going to leave. Next time don't take the Vette if are going to use chains. The owner's manual says not to use chains. The problem isn't just clearance to body panels. There are other things that can be damaged and make the car undriveable.
Bill
Old Mar 29, 2009 | 08:56 AM
Norm_05_ GTO's Avatar
Norm_05_ GTO
00 C5, 05 CTS-V
I run 245/45-17 on all corners with no problems getting in one night with the cables. I bought the chains for insurance as it's better than leaving it parked somewhere when you caught out. I don't run any extra weight in the rear so it's a little slow from a stop but once 40 MPH I can pull on most 4WD trucks!
Norm
Old Mar 29, 2009 | 11:50 AM
lucky131969's Avatar
lucky131969
How exactly do you get "caught out" ? Do you guys get a lot of freak snow storms in Ohio when the forcast calls for sunny and 65?
