Door panel removal
Old Feb 13, 2009 | 01:54 PM
d1278's Avatar
d1278
Cruising
Default Door panel removal
Can you tell me how to remove the passenger side door panel on my 2001 convertible.
Old Feb 13, 2009 | 02:30 PM
Sinister-one's Avatar
Sinister-one
There are 2 T-25 torx screws behind your pull handle that need to be removed first. Make sure your window is down. Now from either side or bottom, pull on the panel and it should start to pop loose from the retainers.
Easy peasy, japaneeeeseee !
Old Feb 13, 2009 | 02:36 PM
d1278's Avatar
d1278
Cruising
Old Feb 13, 2009 | 04:37 PM
vettezeke's Avatar
vettezeke
Dude, Be very careful pulling the door panel loose from the door. The anchor points for the pop in anchors are very easily broken which meens a new door panel. ( Ask me how I know, there not cheap ). Might be worth picking up one of those tools for prying ths anchors loose.
To Door panel removal
