logged codes
Old Feb 14, 2009 | 05:56 PM
Gjman's Avatar
Gjman
6th Gear
Default logged codes
The following codes have been logged by my C5. Can you help me determine what might be the problem?
Thanks,
GJman
C1255H
C1243H
C2120HC
B2723H
B2282H
B2284H
B2262H
B2264H
B2283H
B2285H
B0851H
U1064H
U1016H
U1096H
U1255H
28 TCS - 2 codes
40 BCM - 1 code
A0-LDCM - 5 codes
A1-RDCM - 3 codes
A6-SCM - 5 codes
B0-RFA - 4 codes
Old Feb 14, 2009 | 07:52 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by 8VETTE7
The only one that is current is C2120 which is a TPMS system malfunction. Nothing critical IMHO.
Clear them all and drive the car and see what comes back.
Do you have any other messages such as Service ABS or Service Traction Control?
Bill
Old Feb 15, 2009 | 10:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clear them ALL and monitor. The ones causing issues will come back and then look more closely at those.. Most cars throw spurious DTC's especially in the colder days when cars are driven infrequently. Things like weak battery or low battery voltage after sitting for long periods will cause some history DTCs to set.
Post the ones that come back.
BC
Old Feb 15, 2009 | 05:41 PM
Gjman's Avatar
Gjman
6th Gear
Bill
Bill,
Both message are displayed on the message center.
Thanks,
Cal
Old Feb 15, 2009 | 05:42 PM
Gjman's Avatar
Gjman
6th Gear
BC
How do I clear the codes?
Thanks,
Cal
Old Feb 15, 2009 | 08:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
More reading pleasure on the same subject:
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
To logged codes
