Oil Pressure Sending Unit
Found a part in Rock Auto that Standard Motor Works said would work S619 but it is only the male end. looking for the female piece that is on the sending unit. Has it been done before ?
Why would you need that? What are you trying to do? You still have a fully assembled sender when you relocate. You're just plumbing an oil line to a different location and fitting.
Check out the website and the video. The pictures do not have the unit actually hooked up, the video shows a wire loom going to the sending unit and the kit comes with a pigtail extender to splice in. http://dpecorvettes.com/gpage7.html
I guess once I have all the parts I can fit this as Mark C5 recommends on the first coil pack.
Just looking for options.
Oldvette - did not use teflon tape sending unit had red sealant already on it.
Thanks for the inputs.
Going to buy the DPE relocate unit and do the job again hopefully for the last time!
Dremel off the sender connector...........silly........
Correct, but that is making the assumption the new one already has it applied because you're replacing it with a GM part. If you are purchasing an aftermarket sender such as the Borg Warner part that may or may not be the case.
The splice packs used on C5s are not sealed at all, which makes them subject to corrosion. The exposed grounds are not covered or sealed either. It's a poor design, but it is what it is.
I don't. What do you propose, just using a big glob of RTV on the area you cut off with the dremel? Yeah, that would look the same
Just being specific here. People use these threads as guides for maintence, and someone will put sealant over sealant, not knowing better. I have not seen a factory replacement that did not have sealant on the threads yet.
