Manifold question
Old Feb 17, 2009 | 10:02 AM
2000-C5-JAZZ's Avatar
2000-C5-JAZZ
Default Manifold question
Will a 05-06 GTO/Corvette LS2 Intake manifold fit on a 2000 C5. If yes, what would be the hp gain? Thanks
Old Feb 17, 2009 | 10:05 AM
iced98lx's Avatar
iced98lx
Yes it does, and no gain over the LS6 manifold. Over the LS1 with the proper bits in front a little bit. Most likely not much if you're 100% stock.
Old Feb 17, 2009 | 10:13 AM
2000-C5-JAZZ
Thanks for your help!
Old Feb 17, 2009 | 10:16 AM
LoneStarFRC's Avatar
LoneStarFRC
LS2 manifold is not high in the "performance" or "improvement" category. Use the Z06 manifold on your 2000.
Old Feb 17, 2009 | 10:33 AM
3XLSX's Avatar
3XLSX
It's more of a pain in the *** than anything...The LS6 is a better option
Old Feb 17, 2009 | 11:07 AM
lucky131969's Avatar
lucky131969
Yes, and no.
Old Feb 17, 2009 | 11:31 AM
The Wrench's Avatar
The Wrench
Opinions vary on the improvements seen with a LS6 manifold swap on a stock 2000, but a highly-respected Dallas tuner indicated about 7-8 HP.
I did it, but made some other mods also, so can't document the improvement.
But, if you compare the 2000 to the 2001, the latter has 25 ft/lbs more torque. That's significant.
The changes to the '01 were:
1. Smaller cam with 0.025" less lift.
2. Slightly better air filter lid.
3. larger MAF sensor.
4. Better exhaust manifolds, but 2 additional Pre-cat-converters.
4. LS6 intake manifold.
The lS6 intake had to be a major part of that big torque improvement.
DG
Old Feb 17, 2009 | 07:32 PM
2000-C5-JAZZ
Thank you all for the information. I wanted to another 30-50hp and was going to start there. Thanks again!
Old Feb 17, 2009 | 07:54 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you did choose the LS2 manifold, also realize you will need the mating 90mm throttle body, the adapter wiring harness to make it work with your stock wire connectors, and finally, some PCM tuning changes. Possibly the fuel rail too (not sure if LS1 rail fits over a LS2 manifold).
In short, definitely not worth the cost or effort.
The LS6 manifold would be a relatively inexpensive and worthwhile upgrade, without any of the adapting work needed. (other than the small coolant lines under the manifold that would needed to be updated to the 01/later style to clear the underside of the manifold)
Old Feb 18, 2009 | 09:17 AM
jovette's Avatar
jovette
DG
In addition to increase in torque, and perhaps 7-10hp, you'll also see better throttle response with the LS6 intake on your 2000 C5. The 2000 LS1 engine has the largest camshaft, and therefore stands to gain the most performance of the '97-'00 C5s in an LS1 to LS6 intake manifold swap.
To Manifold question
