2001 Electric Door Lock
Old Feb 17, 2009 | 01:05 PM
d1278's Avatar
d1278
Cruising
Default 2001 Electric Door Lock
My passenger side electric door lock will unlock but not lock.
What is required, and where do I get the parts?
Old Feb 17, 2009 | 01:16 PM
timemender's Avatar
timemender
Could be a relay. Can you hear the relay clicking while working the buttons?
Is it the same result using the fobs, and also the driver and passenger door switches?
Any DIC codes? Forum needs more info for someone to help you.
See this thread.
http://forums.corvetteforum.com/show....php?t=1606865
Old Feb 17, 2009 | 01:46 PM
d1278's Avatar
d1278
Cruising
See this thread.
Yes, there is a click from the door, same result using fob or driver and passenger door switch, no dic codes.
Old Feb 17, 2009 | 01:52 PM
seawolf's Avatar
seawolf
Sounds like computer in door is no longer "communicating" with rest of car. Mine did this and cost about $350 at dealer. There are other fixes to try, do a search and you will find lots of info. Just giving you an idea of dealer cost to fix mine.
Old Feb 17, 2009 | 01:53 PM
RonJ's Avatar
RonJ
Another site that you can look at for info on the problem.
http://www.ronjpics.com/Corvettestuff.htm
RonJ ...
Old Feb 17, 2009 | 03:44 PM
DeeGee's Avatar
DeeGee
This is the definitive thread on door module problems:
http://forums.corvetteforum.com/show...ht=door+module
You can go for the "percussion technique". Bang the door by the module and it may unstick the relay.
Go for the cheap fix which is to take it all apart and replace the relay
Or the full fix which is to replace the door module in toto
To 2001 Electric Door Lock
