Odometer question, I think ive been ripped.
Old Jan 24, 2002 | 09:44 PM
csstereo's Avatar
csstereo
Default Odometer question, I think ive been ripped.
I bought a 98 model C5 about 6 months ago. I recently installed a K40 built in Radar Detector. While installing the detector I noticed first off, the bezel around the cluster has been removed. I then noticed that the cluster itself had been removed, it has a slot in the bottom center that it latches into. And it wasnt in that slot, but above it and scratched up. I contacted the local dealer and they pulled up the service history on the car, and it shows the car hasnt been into chevrolet for service in 2 years! So is it possible someone just replaced the cluster and im screwed? Or is there anyway for me to find out if they have? Thanks in Advance! :confused:
Old Jan 24, 2002 | 10:54 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Odometer question, I think ive been ripped. (csstereo)
i think a chevy tech can pull up the correct milage with a tech 2 :chevy
Old Jan 24, 2002 | 11:12 PM
JohnS's Avatar
JohnS
And if somehow you end up proving that the odometer had been tampered with, I'm sure you would have recourse from the seller. I know how you feel, I bought a BMW once with low mileage but it seemed like too amny things were needing maintenance - even the mechanic expressed concern about mileage and certain repairs not seeming to coincide. I found out later that the odometer could be disabled simply by removing the associated fuse. It is absurd what some people do nowadays.
JohnS
Old Jan 25, 2002 | 08:10 AM
HeliPilot's Avatar
HeliPilot
Default Re: Odometer question, I think ive been ripped. (JohnS)
Particularly if there is a lease involved! :eek:
Old Jan 25, 2002 | 11:12 AM
RyanC7's Avatar
RyanC7
Wonder if that can be done? I can't imagine the computer can tell the mileage.
Old Jan 25, 2002 | 02:16 PM
CP's Avatar
CP
I think the mileage is actually stored in 2 locations - in two different computers. One is for the engine manage and the other is for the instrument cluster.
Old Jan 25, 2002 | 02:24 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Odometer question, I think ive been ripped. (CP)
I also think the mileage would be stored on the PCM, which would also have your VIN embedded in it.
Perhaps the previous owner had white face guages on the car that he removed and this is the reason that it looks like the cluster has been tampered with?
[Modified by MattG, 1:25 PM 1/25/2002]
Old Jan 25, 2002 | 04:23 PM
Kid's Avatar
Kid
A golf buddy of mine once mentioned taking the computer that controls the mileage out and replacing it with one from a wrecked car with lower miles.
He metioned the loss of value from these cars with high mileage.
He said when it came time to sell it, just put the original one back in.
I never really thought about it until now. That is kinda scary.
He is a car salesman by the way..... :eek: :eek: :eek:
Old Jan 25, 2002 | 05:27 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default Re: Odometer question, I think ive been ripped. (Ryan2002C5)
I own a Tech 2 and there is a place to pull up the actuall miles on it.
Old Jan 25, 2002 | 05:48 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: Odometer question, I think ive been ripped. (Kid)
i bet that GM has made sure that there is no way to trick the odometer because of the warranty and the federal laws.
Old Jan 25, 2002 | 08:00 PM
XportC5's Avatar
XportC5
If you find the mileage in the PCM and the cluster do not match, The cluster can be reprogramed to read the correct mileage with a Tech II. You could do a CARFAX on it and get some info there maybe.
Old Jan 25, 2002 | 08:12 PM
antirice's Avatar
antirice
Default Re: Odometer question, I think ive been ripped. (XportC5)
woa don't find out man. when you go to sell the car you will have to tell the actual milage if you know it. If you have no idea that it has been tampered with then to the best of your knowlage that is the actual milage. just keep maintence records every few months to cover your butt. if you really have to find out get a carfax report or some thing that can not be traced to you. You understand what i am saying. You may have a cause for recourse aginst the seller that is if they have the money to give you. Find other indications of milage. how many miles are on the odometer?
Old Jan 25, 2002 | 08:15 PM
jschindler's Avatar
jschindler
Default Re: Odometer question, I think ive been ripped. (antirice)
Would you buy a used car from this man?
Old Jan 25, 2002 | 09:44 PM
RyanC7's Avatar
RyanC7
I assume this would only work on digital dashes?
Old Jan 26, 2002 | 01:32 AM
corvette dave's Avatar
corvette dave
Default Re: Odometer question, I think ive been ripped. (C5SilverBullet)
C5silverbullett,
If the previous owner unplugged the speedo connection at the transmission, wouldn't that keep the miles on both the computer and the dash the same?
Dave
Old Jan 26, 2002 | 02:14 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Odometer question, I think ive been ripped. (jschindler)
It is illegal and some of the horror stories that I have been reading in this forum like theft of a vehicle, people getting screwed in the parts for sale section, etc. I think that anything is possible. I agree - start with a carfax. Good luck and don't worry too bad, after all you own a Corvette :seeya
[Modified by MilYellow02, 6:17 AM 1/26/2002]
Old Jan 26, 2002 | 02:53 AM
TMANN's Avatar
TMANN
I had a problem with my 98 coupe last year when the Hypertech PP III I was using craped out my computer so I called Hypertech and they said I had to send them the computer. I pulled it out of the front passenger wheel well and sent it to them. When I got it back my computer was all messed up. So I called hypertech and they told me to take it to the dealer and have my pcm flashed. I did and when I got the car back my car said it only had 12,000 miles on it when the car really had 30,000. :confused: The dealer said they had no idea what happened but why was I complaining. I said because I want to sell the car someday and im not in to screwing people over. Anyways they had to take my computer out and send it to Chevy supposedly and it took 3 weeks to get the car back. When I got it back they put and extra 5,000 miles on my car (35,000) miles I was pissed and just gave up. :mad I figured I can’t screw anyone selling a car with 5,000 miles less than was on the car and I was real sick of dealing with jack behind people. Anyways I hope you have better luck than me. :confused:
To Odometer question, I think ive been ripped.
Old Jan 26, 2002 | 03:16 AM
maninblack's Avatar
maninblack
thats is one of the reason for not buying a use car :nono:
sorry to hear that, as other said , that it to a dealer and read out the correct
milage form the dme
Old Jan 27, 2002 | 10:00 PM
antirice's Avatar
antirice
Can you honestly tell me that you would take a massive decrease in value that you did not cause? I mean come on man personaly i don't want to take a hit to the pocket book that is going to cost me thousands of dollars. If i don't know some thing about a car i own i am not going to tell some one about it. I mean come on man do you want to take the time to find out some thing that might cost you money. Personaly i would not. It is common sense don't look for things that are going to hurt you. I know if i were buying a car from some one i would want them to tell me everything they knew about the car. When i sell a car i tell anyone who buys the car everything that i know about it. It is all you can ask.
Old Jan 28, 2002 | 11:11 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
When the dealer pulled up the history,what was the mileage for the last repair compared to the mileage when you bought it???Even though it was 2 years since it was serviced,you can get a basic idea on the difference in mileage...For example,if it had 20k on it when it was at the dealer for service,and it had 15-20k on it when you bought it 2 years later,something would be fishy...Look for oil change stickers on the door jam and else where for documented mileage...
