Hurst shifter noisy..
Old Feb 21, 2009 | 05:45 PM
k0ts's Avatar
k0ts
Default Hurst shifter noisy..
Ok.. It's not the shifter but the shifter doesn't seal engine and road noises.. Anyone come up with an easy fix?? I love the shifter but
don't love the extra noises...
thanks
joe
Old Feb 21, 2009 | 08:53 PM
bumble-z's Avatar
bumble-z
This is the way I silenced mine back in 03. It's been quiet ever since. http://www.z06vette.com/forums/showt...threadid=44115
I used Jub Jub's post (DIY Silence that Hurst shifter (pics) Good luck.
Old Feb 21, 2009 | 09:27 PM
Corvette Don's Avatar
Corvette Don
Originally Posted by bumble-z
This is the way I silenced mine back in 03. It's been quiet ever since. http://www.z06vette.comforums/showt...ht=quiet+hurst
Linky no worky. I also have this issue but it does not bother me that much...
Old Feb 21, 2009 | 09:52 PM
Konstantin's Avatar
Konstantin
http://www.z06vette.com/forums/f117/...13/index3.html
but pics are no longer there, its on old article. but id like to see pics of this mod if someone;s got them.
Old Feb 21, 2009 | 10:56 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
What I did was buy a rubber plug from Ace hardware. If I remember correctly it's the second biggest size they sell. It looks like a stopper. Tapered. Then I drilled a hole through it with a spade bit the same size as the shifter shaft. I think it was 1/2 inch. I put the plug on the shifter shaft big end down, then used a tie wrap to tighten the gasket up to the plug. The cost was under $3. No more noise.
If needed and if someone can tell me how to post pix I could post one.
Old Feb 22, 2009 | 10:28 AM
Patches's Avatar
Patches
I used a 1-1/2" version of this Fernco plumbing plug I got at Home Depot. I cut a hole in the center of it just large enough to fit over the Hurst shaft and pushed it in place. I enlarged the hole size for my MGW shifter. Works great.
Old Feb 22, 2009 | 11:10 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
thanks
joe
I wrapped alot of teflon tape on the shifter threads then twisted the oem shift **** back on. Worked like a charm!
Old Feb 22, 2009 | 09:29 PM
TEXHAWK0's Avatar
TEXHAWK0
I trimmed the factory rubber boot to fit tight around the base of the Hurst shifter, and have not had a noise problem.
To Hurst shifter noisy..
