C5 Headlight adjustments?
Old Feb 22, 2009 | 05:19 PM
DBLX's Avatar
DBLX
Default C5 Headlight adjustments?
Is there a "how to" on this? I lowered the front end, so my beam is not correct.
TIA,
MJ
Old Feb 22, 2009 | 08:29 PM
byronhunter's Avatar
byronhunter
From the service manual----
Horizontal and vertical aiming of each of the composite headlamps is done by turning adjusting screws which move the headlamp capsule in relation to the headlamp frame. The horizontal adjustment screw (1) is located on the inboard side of each of the headlamp assemblies, covered by a plug (2) on the headlamp bezel. The vertical adjustment screw (3) is located on the inboard side of each of the headlamp assemblies, below the lower edge of the headlamp bezel.
Old Feb 22, 2009 | 09:11 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Be very careful trying to adjust the headlights.
The adjustment rods have a tendency to "junk" up on the gears inside the housing and snap when forced. The rod itself is not a replaceable item and GM hits you up the the entire assembly.
Try very gently to rotate them in each directions to work them loose. If they are bound up they can usually be freed by removing the headlight surround and soaking the adjustment housing several times over a day or so with PB Blaster. That worked on mine.
Old Feb 22, 2009 | 09:18 PM
TEXHAWK0's Avatar
TEXHAWK0
The access plugs have probably fallen out by now, so you won't even have to remove them to make the adjustments!
The plugs are know to vanish in thin air.
To C5 Headlight adjustments?
