Odd, Turning Signal Buzz Problem
Old Feb 23, 2009 | 03:36 AM
RichDash's Avatar
RichDash
Default Odd, Turning Signal Buzz Problem
I picked up a C5 a couple days back, It buzzed once while on the test drive when I used a turning signal. It didnt do it again only once. Well this AM i get up and every time i try to use the signal it buzzes at me. Tonight i went out and it worked again. I wanted to know if anyone has had this problem before and what it might be ? I searched quite a bit and saw no one with this same issue. All i can think of is replacing the turning signal and hazzard module. I would rather know for sure that this needs to be done then going in blind though. Thanks for any help...
Old Feb 23, 2009 | 10:29 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've never heard of that either but yes, start with cycling the hazard switch several times then past that you can pull the headlamp switch and clean it or replace it. Where is the buzzing coming from?
