traction issues
Old Feb 23, 2009 | 02:43 PM
derrick frasier's Avatar
derrick frasier
Default traction issues
I have some tractions issuses that 295/45/17 mickey thompson drag radials cannot overcome.2800 stall,315 gear and about 395 rear wheel horsepower.a4 transmission.works great at track,but on streets is a different story.are there any suspension mods such as better shocks or any other traction parts out there to try?
Old Feb 23, 2009 | 03:00 PM
Slow Z06's Avatar
Slow Z06
So your spinning them on the street or they just stick?
Driver mod?
Old Feb 24, 2009 | 11:05 AM
derrick frasier
they are spinning real bad.even under light acceleration
Old Feb 24, 2009 | 11:22 AM
lucky131969's Avatar
lucky131969
Where are you located, and what is the temperature? My M/T's dead hook on the street, and I'm at 520RWHP.
Old Feb 24, 2009 | 11:49 AM
Slow Z06's Avatar
Slow Z06
What PSI is in them? What are the temps outside??
Old Feb 24, 2009 | 12:03 PM
black98c5's Avatar
black98c5
How many miles do you have on them? Maybe it's time for a new set. When I had MT's on last year (275/40/17) with 400+rwhp 3:73's/3600 stall, I dead-hooked them Street and track.
Old Feb 24, 2009 | 04:57 PM
derrick frasier
columbia,s.c. new set of 295/45/17 mickeys.I've also tried 325/45/17 m&h tires.50-55 degrees farenheit 23.5 psi in mickeys and 18 psi in m&h tires
Old Feb 24, 2009 | 05:14 PM
lucky131969
Old Feb 24, 2009 | 09:05 PM
zoomz's Avatar
zoomz
The M/T's are a track compound with groves cut in them to pass DOT but the compound is not ment to drive 50 miles on the street .
If you do a burnout it cleans the oils from the road off the tread but if you drive a few miles and try to launch from a light(were everyone sits and drips oil and stuff) they get glazed over .
Old Feb 25, 2009 | 07:55 AM
Blu's Avatar
Blu
Tires aren't your problem its the road temps. Its been in the low 50's and hitting 20's at night over the last week or so. There is no magical tire that will hook in these conditions.
To traction issues
