I'm hardwiring my radar detector to my rearview mirror on my C5. Can someone tell me which wire is switched hot? I assume the black wire is ground, but there are 5 or 6 other wires to choose from for the hot wire. Naturally, I want it to be the one that becomes hot with the key turned on.
Don't you have a electrical tester? Most householders have bought a cheapo one for some project. If not, they're only about 10 bucks, and you'll need it again.
Duh. Thanks for stating the obvious. I don't know what I was thinking. I have multimeter. I guess I was just looking for an easy way out. I found the brown wire to be switched with the ignition. Thanks again for pulling my head out for me.
No problem. I looked at the same thing a few years ago, when I did mine. The brown wire is the same one I used (IIRC) but it will cycle off when you shift to reverse.
mine also was the switched brown wire 12v and black ground,and also cycled off in reverse,but get this,i knew it wasnt supposed to be like that,so i inplugged everything,WITH THE DOORS CLOSED,as intructed on the invisicord web site,and thinking i did have the doors closed the first time,i tried it again,and now it doesnt cycle off in reverse,who knows!
The standard c5 mirror: orange wire hot and black wire ground,
The autodim mirror: brown wire hot and orange wire (2nd wire in) is ground
Hope this helps
For the Electrochromatic mirror the orange wire is not a ground, here is the pin out.
If you are holding the mirror, looking at the back of it, the connector should be numbered 1-7, starting near the middle and going outward towards the outer edge of the mirror. The wires should be inserted like so:
1 = Brown (Hot from headlight switch)
2 = Black (Ground)
3 = no wire
4 = no wire
5 = no wire
6 = Orange 2 (Hot from the door switch)
7 = Orange 1 (Hot all the time)
