Manually raise window?
Old Feb 24, 2009 | 05:32 PM
wreakhavoc's Avatar
wreakhavoc
Default Manually raise window?
Apparently a computer problem has caused the passenger side window to stay down. I can't locate a fuse for it- none is listed on the fuse box diagram. I took off the door panel assuming I could just reach in and lift the window up but it won't budge. How can I get the window up until I can afford to take it to a shop to get it fixed?
Old Feb 24, 2009 | 06:09 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
A quick check might be to inspect the accordion bellows between the door and the "jamb" sometimes there will be a short there which causes many a malfunction. You might be able to grab and jiggle the wiring and the window might go up... If so, that's the place to fix it. Look for a wire grounding when it's not suppose to. good luck. Do a search on window problems and you'll find lots of checks to do as regards the solenoids. hope this helps.
Old Feb 24, 2009 | 06:12 PM
wreakhavoc's Avatar
wreakhavoc
Thanks but I already tried that. I know it's a computer problem because of other things going haywire too. I just need a way to get the window up manually for now until I can get it fixed permanently.
Old Feb 24, 2009 | 08:37 PM
Nick1's Avatar
Nick1
Do a search on window motor problems. I have seen lots of "tricks" in the past.
Old Feb 24, 2009 | 09:53 PM
TEXHAWK0's Avatar
TEXHAWK0
The drive system is designed where the window will pretty much stay where the motor stopped. The gearing is such that you will not move the window without turning the motor. If you cannot tap on the motor and get it to work, you may have to cut the cables, move the window up, and replace the drive assembly when you get the problem fixed. If you are sure the problem is not in the motor, I would try to avoid having to replace the window regulator assembly. It is easy to do, but cost about $400.
Old Feb 24, 2009 | 10:29 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Sorry wrong forum.
To Manually raise window?
