We completely re-designed our C5 fan package with a laser cut aluminum shroud and two Spal 12" high performance fans. The fans pull 3200 cfm which doubles the factory volume and we incorporated four rubber flapper valves for reducing back-pressure at high speeds. The best part is we modify the Spal wiring with a custom plug that matches the Corvette wiring harness. This unit fits factory single row radiators or our double row Direct Fit units.
hello i have been looking into getting your setup including rad. with EOC and your new fan shroud and all hoses and fittings needed for install i am just wondering if there will be any interferance issues with a A&A procharger intercooler and the aftermarket fans if not i would like to get a qoute on all that shipped to 75080
