Coolent for C5
Old Feb 27, 2009 | 10:17 AM
4U2ENVY's Avatar
4U2ENVY
From: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
Default Coolent for C5
I just reinstalled my antifreeze tank last night and placed the coolant that I was able to capture when I diconnected the hoses. Note: I pinched the S hose to the block with vice grips after it was diconnected. I lost some coolant, yet I still need to add coolant to the tank.
Question: Do you have to bleed the lines and if so, how?
Also, does anybody have any recomendations on which coolant that I need to use, or just replace it with the manufactures recommendations?
Where is the best place to purchase the coolant?
Old Feb 27, 2009 | 11:17 AM
SUNNYD 95's Avatar
SUNNYD 95
G.M. says to replace the coolant with Dex Cool. And you should'nt have to bleed the system also you can get the coolant at just about any store.
Walmart, autozone, car quest, pep boys.
Old Feb 27, 2009 | 11:57 AM
El original's Avatar
El original
Default Coolant replacement
When adding or replacing coolant in ANY GM vehicle....always replace with Dex cool the manufacture insists on. Your cooling system with corrode with ANY other coolant. Dont mess with this one!!
Old Feb 27, 2009 | 12:07 PM
4U2ENVY's Avatar
4U2ENVY
Thanks for the info.
Old Feb 27, 2009 | 04:31 PM
TEXHAWK0's Avatar
TEXHAWK0
If I understand your note correctly, you are reusing all the old coolant you could capture.
I would not risk putting old coolant back in. In fact, it would be a good time to drain the rest of the coolant and refresh the whole system.
Old Feb 28, 2009 | 08:51 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Dex-Cool mixed with Distilled water 50/50.
Old Feb 28, 2009 | 10:26 AM
Oldvetter's Avatar
Oldvetter
There are no "bleed" vents on a C5. The shop manual says to replace cap and alternately rev engine to 3,000 rpm until temperature gets to 210 F. Then add coolant as needed. Do this 3 times, adding coolant to 1/2 inch above cold mark.
To Coolent for C5
