I need help!
Old Feb 27, 2009 | 12:26 PM
justin_heat05's Avatar
justin_heat05
Default I need help!
I'm trying to add fluid to my automatic trans in my c5. I need to know where the plug is located on the automatic and the exact procedures for checking it.
I found a plug on the driver's side of the trans and I'm not sure if thats the fill plug. I tryed to add some fluid and it just leaked back out while the engine was running.
Someone post a picture of the plug your suppose to remove to check the fluid or add.
Old Feb 27, 2009 | 12:36 PM
C4B4the04's Avatar
C4B4the04
Thats the one, and its full (it runs out when its full)
Sounds like you are good to go.
What made you think its low?
Cassidy
Old Feb 27, 2009 | 12:43 PM
justin_heat05
Cassidy
Seems to have a small leak, and ive had the radiator off a couple of times. No fluid is coming out when i remove the plug and it won't take any either. The plug I'm taking out is a 10mm bolt head that's countersunk into the side of the trans.
Old Feb 27, 2009 | 01:32 PM
timemender's Avatar
timemender
The drain (& fill) plug is on the driver’s side of the automatic’s oil pan – bottom of the transmission, of course.
With the transmission up to temperature and idling (engine running) and on a level surface –
Depress the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to PARK.
The proper fluid level is the bottom of the fill/drain hole - ENGINE RUNNING.
Wear mechanics gloves and be aware of the HOT exhaust pipe.
Old Feb 27, 2009 | 01:37 PM
justin_heat05
Can you post a picture? I must be overlooking it or something.
Old Feb 27, 2009 | 02:21 PM
C4B4the04's Avatar
C4B4the04
Its like a 3/4 in giant plug on the drainpan. The pan is really easy to identify.
I don't know what metric thing you are talking about. The fill plug for these is in the pan. Maybe somebody else might know what that part is for.
Cassidy
Old Feb 27, 2009 | 05:23 PM
byronhunter's Avatar
byronhunter
Old Feb 28, 2009 | 12:10 AM
justin_heat05
Originally Posted by byronhunter
Alright, i'm really confused. I have a plug like this in the rear of my car. Is this right?
Old Feb 28, 2009 | 11:04 AM
byronhunter
Yes, the transmission is in the rear.
BH
Old Feb 28, 2009 | 11:14 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Where is the 10 mm bolt head you are talking about located if it wasn't at the rear of the car?
Old Mar 2, 2009 | 12:08 PM
justin_heat05
Alright, i'm new at workin on vettes and had no idea the trans was in the rear. Thanks, that plug is a lot easier to get to then the other plug I was trying.
To I need help!
