? for welding x-pipe...
Old Jan 25, 2002 | 06:51 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default ? for welding x-pipe...
I want to weld the x-pipe in place. What type of weld should be used? Is MIG with argon gas ok? Thanks :cheers:
Old Jan 25, 2002 | 08:04 PM
Finnish Vette's Avatar
Finnish Vette
Default Re: ? for welding x-pipe... (3VETTES@HOME)
Has anyone heard cars with the same exhaust, the other with the weld X-pipe and the other with the corsa X-pipe? Are the sounds different? If they are, which one's better? And Why do you think so? How about HP gains? :cool:
Thank you :D
Old Jan 25, 2002 | 08:12 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: ? for welding x-pipe... (Finnish Vette)
sorry Finnish Vette...I'm talking about what type of ( welding ) material should be used to join two pipes together :chevy
Old Jan 25, 2002 | 08:21 PM
Finnish Vette
I know that :D Just asking about x-pipes.. the difference between those two. :cheers:
Old Jan 25, 2002 | 08:39 PM
3Vettes@Home
Cruise-In V Veteran
I'm not sure about the differences..I'm using a magnaflow x-pipe, I can say it has a true X crossover, unlike some of the others :cheers:
Old Jan 25, 2002 | 08:49 PM
borba's Avatar
borba
Mig (metal inert welding) is fine for exhaust systems. Argon is a inert gas that squeezes the arc to produce a hotter arc. If you can find a mixture of C02/Argon or just 100% C02 you will be fine. I like the FCAW (Flux core arc welding) process. Its the same machine but the wire has flux embbedded in the wire so you do not need to have a inert gas. Have fun!
Old Jan 25, 2002 | 09:01 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: ? for welding x-pipe... (borba)
Thanks Borba , I have access to a mig using 75/25 argon mix...I'll give it a try :cheers:
Old Jan 25, 2002 | 09:09 PM
Tiger Shark's Avatar
Tiger Shark
Hi 3Vettes.
I went through a really bad experience with X-Pipe welding. Hopefully my thread(s) will help you out.
I think I removed the pics since the time I posted the threads, but hopefully the text will help.
Eventually, I'll get another X-Pipe installed, and welded correctly.
Regards,
TargaC5
http://forums.corvetteforum.com/zerothread?id=150169 http://forums.corvetteforum.com/zerothread?id=151852 http://forums.corvetteforum.com/zerothread?id=140585
Old Jan 25, 2002 | 09:33 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: ? for welding x-pipe... (TargaC5)
Wow! thanks for providing an eye opening situation!...I think now, I will just clamp into position. Thanks for sharing :cheers:
Old Jan 25, 2002 | 09:42 PM
Tiger Shark
NO NO NO!!!! That's not why I posted my story. Just make sure that the place you have the cutting/welding done at knows what they're doing. I'm still going to get another X-Pipe in the future, and I will be getting it welded (correctly this time). I'm also going to have my Corsa Indy exhaust welded where the rear section clamps to the part with the mufflers. Good luck!
Regards,
TargaC5
To ? for welding x-pipe...
