Electrical EXPERT Battery drain hel
Old Mar 1, 2009 | 12:10 PM
MSO4's Avatar
MSO4
Default Electrical EXPERT Battery drain hel
My battery seems to be draining. After not driving for 3-4 days, the voltmeter from the car shows 11.1-11.3V and the engine turns slowly on start up. After a drive, it cranks faster.
And looks like I'm getting 140mA when in sleep mode but I'm not sure I did the connections right. First picture shows my connection. Second shows my ammeter.
Also, I pulled all the fuses from engine compartment and under the dash but nothing changed. Thanks for your assistance.
Old Mar 1, 2009 | 01:04 PM
nastymant's Avatar
nastymant
it looks like you scale is already reading milliamps (mA), so that is .14 mA not 140.
Old Mar 1, 2009 | 02:44 PM
MSO4's Avatar
MSO4
Stupid me I didn't even notice that!
But is that real? Shouldn't I be draining at least 10-20mA instead of just .14mA.
Old Mar 1, 2009 | 06:51 PM
MSO4's Avatar
MSO4
Just realized my volt meter lead is wrong. I should have put the red lead over where it says DC 10A on the left instead of the right.
When I did that, I get about 70mA with the doors open. After 10 min, it reads 30mA, and within 5 min of that it read 2mA. So looks like my electrical system is ok.
I just drove the car for an hour and when I come back home, the volt meter across the battery shows 12.3V. So looks like my battery is going bad. I will take it to Pep Boys and maybe they can replace it.
Old May 26, 2009 | 06:28 PM
MSO4's Avatar
MSO4
Yup, it was the battery. After a full charge, everything is good now.
To Electrical EXPERT Battery drain hel
