Battery Connecting Causing Damage?
Old Mar 16, 2009 | 06:25 AM
Don Lindeman's Avatar
Don Lindeman
And never put your tounge across your Vett's battery terminals!
Old Mar 16, 2009 | 06:50 AM
RonJ's Avatar
RonJ
I have been involved in the automotive service industry since 1961, under no circumstances have I received a shock from handling 12 volts, even from terminal to terminal.
I'm not a welder by trade, but I have done a fair bit of welding using a "stick" arc welder. Again, I have never received a shock from the electrode when accidentally prodding myself with the rod, a burn maybe, but no shock. I understand that because of the electrical shock danger when electric welding, the open circuit voltage of an electric welder is limited to 26 volts and we know the type of amperage involved. Someone more knowledgeable than I may correct me on this.
I'm not an electrical engineer, but I have survived a few years of practical application .....
RonJ ...
Old Mar 16, 2009 | 01:22 PM
Woodstoc's Avatar
Woodstoc
Perhaps a 8 calorie suit and gloves.......
Old Mar 16, 2009 | 01:28 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Just hook up the battery!!!!!!!!!!!!!!
Old Mar 16, 2009 | 01:35 PM
byronhunter's Avatar
byronhunter
That's a good idea, not a problem!!!!!!!!!!!!!
Old Mar 16, 2009 | 02:22 PM
lucky131969's Avatar
lucky131969
Very funny thread.....all about connecting the battery.........comical...
Old Mar 17, 2009 | 12:35 AM
fnsblum's Avatar
fnsblum
The reason you install the negative last and take it off first is to prevent arching. I just did an amp test to see what load a battery has on it with everything turned off. I had my hood light unplugged. My meter was in series with the positive post and cable. When I first hooked up the meter I could hear a relay energize. The load was 1.25 amps. After a few seconds the relay dropped out and the load went down to 80 MA. A minute or so later the load went down to 40 MA and stayed there. Later! Frank
Old Mar 17, 2009 | 10:59 AM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by ZeeOSix
It only takes a few milliamps across the heart to kill someone ... but it also takes higher voltage to achieve current through the heart path. If shocked while wet by a 12v battery, the current would probably take the path of the wetness along the outside of the body and not put any across the heart. But of course, if you were naked, wet and hooked your feet to the + terminal and your head to the - terminal it might put some amps through your heart. In high voltage electrocutions, the earth is always the negative plane, so at least with a battery you'd have to try pretty hard to setup the right electrical path for a major damage shock.
You need to have somewhere around 30v to stop your heart. My friend is a mechanic and when he was swapping out my battery he was twisting both at once.
Old Mar 19, 2009 | 03:50 AM
ZeeOSix's Avatar
ZeeOSix
It's current through the heart that stops it. Voltage is needed to drive the current through the resistive path - ie, your body. Every electrocution situation is different. If there is enough voltage, and the resistance path through the heart is low, then you can be killed with lower amounts of voltage - meaning you can generate the few milliamps with lower levels of voltage. To be killed with just 30v, the conditions of the electrocution would have to be very special to drive enough current. Not saying it's impossible, but just rare.
But, if the resistance path through the heart is high, then it will take a much higher voltage to drive the same small amount of current through the heart. Ohm's law applies to human electrocution scenarios.
Old Mar 21, 2009 | 01:33 AM
Don Lindeman
Originally Posted by fnsblum
The reason you install the negative last and take it off first is to prevent arching. Later! Frank
Hmm... Even so, it still arcs. There has got to be a difference of potential between the negative battery post and the ground cable in order to have the arcing and sparking.
This raises this question: Is the negative battery terminal more positive or negative relative to the ground cable until the cable is connected?
Don
Old Mar 21, 2009 | 06:49 AM
RonJ's Avatar
RonJ
Don
The reason why it arcs between the post and the cable when you disconnect is because current is being drawn from the battery when you are disconnecting. With a modern car, a small amount of current is always being drawn, even when the car is "off" due to on board computers and relays which are energized all the time.
If your interior lights or radio are on when you disconnect, there will be a very noticeable arc. A battery switch in series with the terminal and cable eliminates most of that ragged arc and I think is easier on the electronics. This is also why the ignition should be "off" when disconnecting the battery. Just the key being in the switch increases current draw.
If you were to be disconnecting the positive terminal first and accidently let the wrench touch a grounded part of the car, there would be a major short and arcing when the positive wrench touches a negative ground. By taking the negative cable off first, you eliminate that danger!!
RonJ ...
Old Mar 21, 2009 | 02:16 PM
Don Lindeman
Ok RonJ,
Thanks to you, my lightbulb just got lit. The arcing doesn't happen while connecting the ground cable, it happens during the momentary DISCONNECTION(s) when you are trying to hold the connector on the terminal while turning the wrench. My over-40 brain cells sometimes have a similar problem, but that's another theory I have.
Don
Old May 15, 2011 | 04:47 PM
  #33
motordavid's Avatar
motordavid
Don
To resurrect an old, but informative thread...I am swapping out the battery, and as I push the neg cable toward the threaded receptacle on the battery, there is a lot of sparking and click, click, clicks.
This is the 2nd new battery, (in 9 yrs), and I don't recall the first swap out producing that kind of sparking...in 50 yrs of battery changing, I have never seen any sparking, on cars, m'cycles, etc.
Pos is on correctly, and tight...should I just suck it up and push this sparking neg cable on, and start the tightening process? Pretty damn weird, imo.
Thanks, mD
Old May 15, 2011 | 04:50 PM
  #34
lucky131969
Thanks, mD
Old May 15, 2011 | 05:19 PM
  #35
motordavid's Avatar
motordavid
Originally Posted by lucky131969
Thanks for the help...
so, I just push through the sparking, stuff the neg cable on, and tighten it up?
Old May 15, 2011 | 05:25 PM
  #36
lucky131969
You have three choices:
1) Pull every fuse, and isolate every circuit on the battery buss, then connect the cable.
2) Have it towed to a shop, and let them connect the cable.
3) Connect the cable, with an understanding that modern vehicles have many systems drawing current(with the vehicle off)....besides just the clock.
Old May 15, 2011 | 06:08 PM
  #37
motordavid's Avatar
motordavid
I put on a pair of rubber gloves, sucked it up, and put it on...
no problem.
Just have never seen the neg cable spark like that on this, or any car.
Thanks, mD
To Battery Connecting Causing Damage?
Old May 15, 2011 | 09:02 PM
  #38
65GGvert's Avatar
65GGvert
It's simple, just disconnect the positive terminal. Then the negative terminal won't spark when you connect it. Then when you're ready to connect the positive terminal, disconnect the negative terminal first. That way the positive won't spark either. If you follow these simple directions, neither positive nor negative will ever spark.
Old May 15, 2011 | 09:21 PM
  #39
PEERPSI's Avatar
PEERPSI
Okay, here's the thing. Negative off first on last. If the positive is done first and a wrench slip occurs resulting in a grounded wrench you have just effectively shorted the battery. The high current can and has lead to a rapidly heated battery that ruptures its case. This means hot acid flying around. The short circuit situation also creates a significant fire hazard.
If you are uncomfortable with the sparking or touching the live electrical parts consider hiring a professional.
For those that are willing to do the work consider wearing gloves to avoid shocks and burns.
As for current required to stop a heart, Class A GFCI's, the ones you use in your home, are required to trip at .006 amps. The voltage required to flow that amount of current through the human chest cavity is entirely dependant on the conditions.
Old May 15, 2011 | 09:36 PM
  #40
customworksking's Avatar
customworksking
no problem.
Thanks, mD
I run 2 batteries N my car you'ii get a spark every time .. my truck had 4 .. I done car stereo installs for 4 years or so,when theres a problem all cars seek out the weakest ground ie:all the ground problems with corvettes 13 grounds WTF ! you'll get a spark
