Water Pump Question
Old Mar 4, 2009 | 09:51 AM
wcsinx's Avatar
wcsinx
Default Water Pump Question
I'm pretty sure mine has started to weep a little. I'm getting a very slight belt squeak on cold starts. It looks like an easy enough job.
I have an '02, but I hear people recommending the 04+ pumps because they don't use the (expensive) integrated water neck + t-stat? So if I go this route, I'm assuming I'll also need to pick up a new water neck and t-stat? Is that correct?
TIA
Old Mar 4, 2009 | 10:24 AM
LoneStarFRC's Avatar
LoneStarFRC
TIA
Correct. Separate housing/stat, etc. but it's LS3 pump that seems to be the way to go from all I'm hearing. Better impeller design, lighter, etc. and direct bolt-up.
Give Bob Wendorff, at Fichtner Chev (forum vendor), a call at 1-800-234-5284. You will be favorably impressed with the pricing and they DO NOT gouge you on shipping costs.
HTH
Old Mar 4, 2009 | 10:43 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
The new style replacement pumps from GM come complete with the thermostat and housing installed. Just bolt the pump on.
Old Mar 4, 2009 | 11:13 AM
LoneStarFRC
That's a good point. I forgot about that. I'm so used to Generous Motors selling everything a la carte for year after year.
The LS3 pump still appears to be the way to go though.
Old Mar 4, 2009 | 11:24 AM
wcsinx's Avatar
wcsinx
HTH
Gotcha
Yep, I found a few more old posts suggesting the 05+ LS2 pumps. Is that the same part number as the 08 LS3 pump? It does look to be a better design. I like the smaller bell.
Old Mar 4, 2009 | 11:34 AM
LoneStarFRC
Gotcha
I think the 2 and the 3 pumps are different part numbers. Nice thing about the LS family is the interchangeability of a lot of the various parts though; just like in the days of the old cast-iron small blocks. I'm using the newer designed metal (with "spokes") LS2 styled p/s pump pulley for example. Also a direct fit replacement.
Call Bob. He's very Corvette knowledgeable and can help you out.
Old Mar 4, 2009 | 12:04 PM
Quicksilver Vert 01
The new style LS3 pump has recently become the standardized GM replacement for all LSx Corvette engines. It comes with a 187 degree thermostat and housing.
Old Mar 4, 2009 | 12:27 PM
KCvetteowner's Avatar
KCvetteowner
The new style LS3 pump has recently become the standardized GM replacement for all LSx engines. It comes with a 187 degree thermostat and housing.
I wouldn't go that far, perhaps for Corvettes. The F-body, GTO and CTS-V require that larger bell for their different belt configurations.
http://nookandtranny.com/Info_LSx.html
Old Mar 4, 2009 | 12:36 PM
wcsinx's Avatar
wcsinx
Ahh good deal ... I'm showing the same part # from gmpartsdirect for 05-08. So I think I'm good.
thanks!
Old Mar 4, 2009 | 12:52 PM
Quicksilver Vert 01
I assumed that we are all talking about Corvettes on this Forum.
Old Mar 4, 2009 | 02:24 PM
Last C5's Avatar
Last C5
HTH
Do you know whether the LS3 pump flows more or at least more equally between the two sides?
To Water Pump Question
