MAF wiring harness
Old Mar 6, 2009 | 09:26 PM
bowtiebubba's Avatar
bowtiebubba
Default MAF wiring harness
Can the maf wires be extended? I would like to run those wires around the radiator instead of over the top.
Old Mar 6, 2009 | 09:43 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes! They can be extended - just make sure you put the same wires back together - It can happen
Check here at RACETRONIX they might have the extension - I do know they can make you a plug and play one custom
http://www.racetronix.com/ Check under the wiring solutions if not they will make one for you
Thanks,Matt
Old Mar 7, 2009 | 10:37 AM
bowtiebubba
If i cut & extend the wires,do i have to use the same gauge wire or do i use something else?
Old Mar 7, 2009 | 11:51 AM
LoneStarFRC's Avatar
LoneStarFRC
If you're going to do that, then make sure the wire gauge is either the same or even a tad larger would be OK from a purely electrical point of view.
The only possible problem I see in doing this however, is that the wiring harness will extended by what........6 or 8 feet, maybe more? Electricity, especially low voltage, low current electricity does NOT like long wiring runs. It's called voltage drop. The longer the wire, the greater the potential voltage drop and you're already starting out with a very low level signal. Something to consider.
Old Mar 7, 2009 | 11:44 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Are you wanting to do this for looks? ie hide the wires? If so, why not just run them under the air bridge?
Old Mar 8, 2009 | 09:54 AM
Rossi396's Avatar
Rossi396
I was thinking the same thing...I just installed a Vararam and the air bridge sits just a bit higher than stock. The wires fit underneath it perfectly and the installation looks much cleaner...
Old Mar 8, 2009 | 11:29 AM
bowtiebubba
I have a BBK air bridge and there is no room at all under it. It barely sets down on the pegs now. I emailed racetronixs to see if they make extended harnesses.
Yes,this is for looks.I hate those wires running over the top.
Old Mar 8, 2009 | 03:08 PM
slothy's Avatar
slothy
id use the same gauge wire and solder/shrink wrap connections - then hide wires in flexloom
To MAF wiring harness
