Wiring help
Old Mar 7, 2009 | 09:28 PM
Stroke03's Avatar
Stroke03
Default Wiring help
When I removed the drivers side trunk corner carpeted panel, in the trunk.
I found a 16 ga. light green wire with a black stripe. This wire ran under the trunk carpet towards the front of car. Wire had been stripped and was just laying in area of the removed panel. Everything works and I can find no area that this wire might have been connected. Car does not have ride control, 16 ga. light green wire with a black stripe. Any Ideas. If not I will clip off stripped area, roll up and tape wire under corner trim.
