Power Sterring Fluid Leak
Old Jan 27, 2002 | 03:06 AM
deselfiter's Avatar
deselfiter
Default Power Sterring Fluid Leak
Has anyone experienced a small steering fluid leak? If so, is it an easy repair or to the dealer?
Thanks!
Old Jan 27, 2002 | 03:10 AM
Cajun99's Avatar
Cajun99
Default Re: Power Sterring Fluid Leak (deselfiter)
No leaks on mine...and I hope I never see any either :eek:
Old Jan 27, 2002 | 04:18 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Power Sterring Fluid Leak (Buckmaster)
I had two leaks on my 97. One was a slight weeping from the rack which I got **** about and took it in for the dealer to fix. They replaced the steering rack which led to quite an exciting time for me out on the highway a day or two later. The other time the power steering pump seal failed while I was doing a track event and they had to replace the pump.
Bill
Old Jan 27, 2002 | 04:58 PM
allanlaw's Avatar
allanlaw
Thanks!
Yes (though small leaks get bigger pretty quick), and to the dealer we did go. They replaced the power steering pump, and then replaced it again two days later since the first one was no good (so they say). I don't think it took them too long to do it, although I'm not certain since I left the car both times.
Old Jan 27, 2002 | 05:52 PM
cart3113's Avatar
cart3113
You may want to check the hose where it connects to the pump. The hose is connected with one of those spring clamps. It could have slipped. I replaced mine with a screw type clamp.
To Power Sterring Fluid Leak
